Page 11 of 18 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 174
Thread: Matts MK4 GL Respray & VR6 Conversion
  1. #101
    Apr 2011
    Berwick, Victoria
    You can get a good pedal just letting the fluid flow under gravity, if you have got tons of air in the pipes. Then go around the system again and start at the master cylinder which everyone forgets about.
    Might give that a go seeing as though brake fluid is cheap, thanks Gavin! Much appreciated
  2. #102
    Apr 2011
    Berwick, Victoria
    So I started doing some things tonight (taking off some trim panels) and was going to call it a night, went inside and had a think, then went back in the garage and got things done.
    Seeing as though I was going to take out the dash tomorrow night, I can proceed to take out the seats and follow the wiring loom to wherever it leads.
    If it doesn't fit, make it
  3. #103
    Quote Originally Posted by MCiN7 View Post
    Not guaranteed to be 100% but gets you started.
  4. #104
    Jul 2009
    Geelong, Victoria
    epic conversion, great job!
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
  5. #105
    Aug 2006
    Melbourne VIC
    Matt you want a hand Friday night?
  6. #106
    Apr 2011
    Berwick, Victoria
    Thanks Stan!
    Quote Originally Posted by Water Boy View Post
    Cheers but probably better next Friday as both ECS orders should have arrived, might get a few of you guys around
  7. #107
    Apr 2011
    Berwick, Victoria
    Tornado has now gone through the interior
    Tada, it wasn't actually that bad of a job considering I've taken most of the interior out before...just time consuming
  8. #108
    Mar 2009
    Wagga Wagga
  9. #109
    Apr 2011
    Berwick, Victoria
    Quote Originally Posted by trickysimon View Post
    You're crazy dude! Lol
    Maybe , the wiring loom is easy to take out, the only pita is the various clips and abs sensor loom(s).
    Realised I also need to change my brake pedal - drive by wire has a plate where the pedal bolts on to
    Edit: Something that just crossed my mind, climate control may well need to be changed to the electronic version considering that I'm getting a complete loom from a 4mo
  10. #110
    Apr 2011
    Berwick, Victoria
    Got me some parts
