Good work!
This make me happy!
Good work!
I hope so Woody
Cheers Dylan
Last night
This morning
Engine is ready to pull out but I need an angle grinder to chop the exhaust (no flange around cat area)
it has begun! excellent.
Certainly has
Got my hands on an angle grinder tonight, such a pita to chop the exhaust.
Needed to drop the subframe again for the exhaust to clear but...
It's out!
yay!
Now the real fun can begin.
If you say so, may need to remove the dash for DBW conversion, checking if someone has a loom available.
Removing the dash is not so bad - removing the steering wheel will be a first for me and apparently a pita but the rest is straight forward
Dash removal - Bora - uk-mkivs
But at least if I swap the dash loom, I can assume everything will be working without swapping wires around
