Page 10 of 18 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 174
Thread: Matts MK4 GL Respray & VR6 Conversion
  1. #91
    Apr 2011
    Berwick, Victoria
    Quote Originally Posted by Bflat View Post
    The steering wheel removal isn't too bad Matty. I sat and watched Pete swap out Megan's ****ty one for a Bora Sport one in 5 minutes. Provided you have the threesquare tool and some patience, it's fairly agreeable.
    What is this tool you speak of?
  2. #92
    Eltham, Victoria
    Quote Originally Posted by MCiN7 View Post
    12mm triple square bit
    Here's a handy link -> steering wheel swap VW Jetta Golf GTI Passat
  3. #93
    Apr 2011
    Berwick, Victoria
    Awesome, thanks!
  4. #94
    Apr 2013
    this ride is going to be sweeet! also check out trade tools for cheap tools, got a set with hex, torx and triple square for around $30
  5. #95
    Apr 2011
    Berwick, Victoria
    Andddd it's dark...
    Engine bay is already gutted, garage is getting messy - will need to move some things into the shed.
    Tomorrow nights plan is to get it back to be a rolling car (rotors & wheels) so I can start to clean the engine bay & take out the front section of the interior.
    Quote Originally Posted by kdog View Post
    Thanks! Will do - don't need many tools but I will be getting a roller cabinet for tool box locally
  6. #96
    Jun 2008
    melbourne
    Progress is coming along well matt.
    Keep it up.
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
  7. #97
    Apr 2011
    Berwick, Victoria
    Quote Originally Posted by Silver dub View Post
    Keep it up.
    Thanks!
    Can't report on much - waiting on quite a few parts .
    Seeing as though I'm getting all the required looms, wiring won't be a problem but I'm starting to think about bleeding the brakes with no/part fluid in the lines - have had a low pedal before and don't want that again. My best bet may be to get the car towed to a vw specialist or vw themselves to hook up a machine.
    Gave the engine bay a degrease, scrub and gerni...so much cavity wax everywhere (possible previous owner front smash, have never seen so much cavity wax on places that it doesn't need to be). Also needed to clean up some CV grease as I had a split boot.
    Friday night I'll attempt to take out the dash
  8. #98
    Jun 2007
    Eastern Suburbs Melbourne
    You can borrow my power bleeder if you want Matt?
    but why would you have low fluid in the lines? you've already swapped brakes havn't you?
    i like volkswagens
  9. #99
    Apr 2011
    Berwick, Victoria
    Cheers - Going to have a heap of air in the system, maybe not be from the top end, although I've got to add the clutch/lines which I have to cut a nipple on the reservoir (some fluid will escape)...BUT...stainless brake line kit which includes front, mid & rear, so I will have air in the lines in many places, not just at the ends.
    If I fill a Power Bleeder up with a few litres of fluid it may be okay, but I wonder if it's just easier for VW to hook up their machine.
    I just don't want a low pedal again
  10. #100
    You can get a good pedal just letting the fluid flow under gravity, if you have got tons of air in the pipes. Then go around the system again and start at the master cylinder which everyone forgets about.
