why does the box say 1.8lt when your building a 1.9?
dom
The old bunny has been tired lately....so time to do something!
Building a 1.9 8v engine for her(82.5 piston,custom Pauter rods) along with a few other goodies.
Will be running oversize brake/calipers on her, braided lines etc..
Currently running KW v3 coilovers.
Watch this space...
Audi S3 8L - Stroker GTX3582 700bhp+
Golf GTI 1980
Golf GLS 1979
www.facebook.com/etunersmotorsportau
dom
Golf GTI 1980
Golf GLS 1979
yeah i know why and how to stroke a motor... was just asking why they would put 1.8lt on longer 1.9 rods
dom
Wouldn't know man. Maybe to indicate that there custom or something, instead of people thinking there of the shelf.
Golf GTI 1980
Golf GLS 1979
Okay....
Engine and gearbox out, we weren't sure if it was a Heron so when we had a look we were quite surprised.
Cao.
Golf GTI 1980
Golf GLS 1979
Nice dude. Glad to see you & your dad doing some upgrades to get this thing going.
The Part # appears to be a Pauter Rod number! Way overkill on this type of engine, but if your happy to spend the money. Go for it.
Just for interest sake. A bloke down here who use to build F2's engines said they use to spin there 1.6L to 10K on stock rods & they are very strong, even for forced induction too.
One thing I'm not too sure on though, is you've got a 1.6L but fitting 1.8L rods? This doesn't actually increase the capacity though, cause your crank stroke/offset is still the same.
All that fitting a 1.8L 144mm rod onto the stock 1.6L crank will do is move the piston out of the block!
To increase capacity, you need to offset grind your crank journals to increase the offset & stroke & using the stock 136mm rod you'll also need custom pistons with different piston pin heights to compensate for the increased stroke.
Many many moons ago Autotech did a 1.9L stroker kit using a US spec 1.7L crank, 136mm rods & with a 83mm Techtonics Tuning custom piston brought the capacity to 1869cc
So maybe just ask some questions why or what your using those rods for, unless your fitting a 1.8L crank to? Not sure if these fit in 1.6L blocks either
I have also read that some people used to run a offset ground 1.8L crank & using the earlier 136mm rod & custom/decked pistons, they can stroke the 1.8L too!
I do know on some stroker kits though, that the intermediate shaft may need some machining/clearancing
Thanks Tim!
We are using a 1.8 block( bored out and balanced bottom end), with a 1.8 crank and 84.2mm pistons. And yes, they are Pautor rods
Interesting facts there but.
I should of mentioned it, but a 1.8 block is getting prepared on the side ready to pop in the mk1. The 1.6 will just be put aside.
Golf GTI 1980
Golf GLS 1979
Ah ok.
So your not using the Heron head then? Unless you buy some very specific heron head style pistons or have them custom made
Just remember & I think we've been through this before. You can't go to 84.5mm pistons.
3.5mm overbore from what I know can't be done! Thats a 0.137 Thou Overbore & will probably end up in the water jackets!
From what I know & can find 83mm (83.5mm is the largest for a 2L block & very rare for a 1.8L block) piston are the largest piston you can buy for a 1.8L block & even then it isn't advisable for a track engine as this also causes cooling problem under extensive high load/pressure
Golf GTI 1980
Golf GLS 1979
