Page 7 of 12 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 111
Thread: Little makeover for the '79
  1. #61
    will you be running carpet/flooring of any sort?
    No carpet for this one. Just a very smooth paint job.
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  2. #62
    Ready for welding and other modifications
    Found a bit of rust...
    Golf GTI 1980
    Golf GLS 1979
  3. #63
    Quote Originally Posted by Oneofthegreats View Post
    This may put the pistons down the bore (with increased deck height/more clearance volume = less compression!) if you plan on using a 1.8L crank & 144mm rods
    Thats why we had to use custom rods. If we were to use 144mm rods, it would push the piston down= to less compression like you said. Thats if you were using a 82.5mm piston. Audi 1.9 has a lower pin position in the piston, hence why it wont lose compression using a 144mm rod.
    Golf GTI 1980
    Golf GLS 1979
  4. #64
    Jan 2009
    south west sydney
    Quote Originally Posted by 16v_kid View Post
    i hope you mean you're raising the strut toweres
  5. #65
    Quote Originally Posted by MiKe1_golf View Post
    hah, you wish!
    Golf GTI 1980
    Golf GLS 1979
  6. #66
    Sep 2007
    looks pretty good gordo.
    i've always been curious about the twin master cylinder set up... where are you sourcing it from if you don't mind me asking?
    87' MK2 GTI
    13' MK7 TDI
  7. #67
    Quote Originally Posted by jayjay View Post
    Cheers Jayjay.
    Where not going to be running the twin master cylinder yet. This is a temporally fun thing. Car will be striped to bare metal to complete resto, and go on from there. Then we will install twin master cylinders and bit and pieces like that.
    -Intermediate shaft.
    and.....
    Golf GTI 1980
    Golf GLS 1979
  8. #68
    Sep 2006
    Australia?
    You do realise its not a GTI?
  9. #69
    I've got a certificate from Wolfsburg that tells me everything about it. And I'm pretty sure it say's GTI.
    Golf GTI 1980
    Golf GLS 1979
  10. #70
    Sep 2006
    Australia?
    Sure they did mate, sure they did
