Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: GTi motor: carby to efi
    Jun 2008
    Hobart, TAS
    thanks for the help guys, just wanted to clarify a few points.
    as for the engine code jean i haven't got the motor yet and have not viewed it either, will do in the coming weeks.
    I think it is the GT motor as you said but will confirm this later.
    there are a heap more wires for fuel injection obviously?
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Mar 2007
    South Brisbane
    If you run a early k - jet you need to wire up a electric fuelpump, coldstart injector (i run mine off a push button in the cab) and warm up regulator (mines not even plugged in) thats it turn key and it will run the later model
    k -jets are a bit more complex.
    Camden, Sydney
    I wouldn`t go kjet these days with a fresh install, use aftermarket efi, or wire in the digifant from a Mk2 or 3. All the kjet bits are getting old and expensive and it is not understood by most mechanics. EFI will be much more reliable and cheaper.
    Jan 2008
    gotcha code yet?
    Golf MK2 Project
    Daily car: Audi 90 2.3L 5cyl manual
    "I run everything under pressure, from my supercharger to my blood"
    Jun 2008
    Hobart, TAS
    Quote Originally Posted by jeanheide View Post
    gotcha code yet?
    Nope no code yet, will probably just stick with the carby setup for now and maybe go efi later on down the track.
    I'm just wondering now about fiddley little bits, like speedo cables etc, will most things plug n play with the 1600 components?
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Jan 2008
    basically all vw engines are the exact same just built in diff sixes in regards to plug and play. some things will be different like your fuel pump management etc. efi has a electric fuel pump and the carby and k/ke jetronic i think had a mecanically driven one. dont remember.
    but otherwise it plugs straight in incl your speedo cables etc.
    my caby doesent have a 2nd thermostat tho. to change between engine flow and engine radiator flow so some sensors from the efi wont plug in. but otherwise my gti tacho fits into my gt, cus it has a gti tacho in it
    if you need ne help just ask me cause im constantly screwin around on my car.
    Golf MK2 Project
    Jun 2007
    Eastern Suburbs Melbourne
    Kjet runs an electric fuel pump.
    speedo cable runs off the gearbox anyways,.
    Depending on your future plans, I'm going to echo the sentiments of running aftermarket EFI. Kjet is a bit of a lost art, where as EFI is still getting more popular, if that makes sense at all. So many options out there, a number of budget ones too.
    i like volkswagens
