sounds like you've got a few issues to iron out, but boy oh boy it will haul when you're done!
Me and my best mate Yee have been working hard this weekend even though we didnt get to much done it was a good taster of what we need to do next weekend!
So i will get pics next week for ya,
The good news:
The Kinetic Morotsport Manifold fits a 1.8t swap in a mk2
The turbo will fit under the rain tray with no worries.
IC piping will be OK to do
The not so good news.
The heater matrix line will need changing.
My shinny Alpine white firewall weill need some heat shield.
The bad news
Downpipe is going to be a ****, we had one virtually done yesterday but it sat about 2cm from the timing belt, not to sure how much heat they can handle?
The problem: RHD - brake booster and then mk2 rear engine mount is in the way so the DP is a tad tricky. Also there is not a lot of room for the Tial.
90 GTI Mk2 1.8t soon to be with GT28rs
you could make up a shiny heat shield to mount on the DP to protect the timing belt.... but another question - the timing belt is behind a cover??? if so, just a heat shield should be fine (would be tight, but hey, thats the way its gotta be sometimes). If the timingbelt is not behind a cover..... sounds bad.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
yer it is behind the plastic cover, I will have to shield it but you know with a good 600 hundred degrees it may get a tad warm down there!
keen for an update tommymac, how is it going?
Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
Mk1 twin eng twin turb
scirocco gti 2.1l 16v turb 6spd
Audi A4 B5 1.8t
hey,
all good ill get good pics up next week when its back from ceramic coating. It was not easy but we have got it all to fit and look nice. so keep your eye out for the pics
You could do an exhaust wrap AND a heatshield. Sounds like the exhaust is going to be nicely coated though. Don't wanna cover the shinyness up!
Good luck!
