Results 1 to 10 of 43
Thread: cooling on an AGU
    Jun 2006
    Hornsby
    the pump[ was just replaced with the ones with the metal pump as i know the plastic ones **** themselves a lot, i dont have an OEM cluster atm so I am using the after market one in the bottom hose, now i did have a thermometer in the top hose and thats how i know the temp was at 90 degrees
    How long was the engine running for. It's possible that the top hose/rad were only heated by conduction and not by the water flowing around the engine.
    The water at the stat might not have been warm enough to open it up?
    Jun 2006
    Hornsby
    unless the radiator being upside down is an issue?
    Nah, dont see that as a problem, the water wont know which way its going through.
    Same with an intercooler, it might flow better one way but not that big a percentage difference in flow that it would cause any issues.
    Did you test the stat before fitting it?
    Has it boiled over at all?
    Jun 2006
    Hornsby
    the stat is the original stat so im assuming it works, now the car was at 90 but yes it may not have been 90 in reality, erm no it hasn't boiled over and im not sure what temp AGU thermostats open at do you know? and should i put the thermometer near the stat?
    Camden, Sydney
    Try adding more coolant to the system when it is cold and see if it takes more. There may be air bubbles causing false readings.
    I`m more excited by the fact that you have an AGU running in your Mk2
    Now we want pics.
    Aug 2007
    Never assume with a stat mate, i think thats it. Ive had new ones from the box munted too mate. Starts to open at around 82 degrees approx and finishes opening around 105 degrees. Doesnt matter if the rad is upside down, the rad cools across the way, headers are at each end and not top like back in the day. Coolant flows across from the top hose to the bottom hose. If the stat is stuck i would say the heat on the top hose is the heat transfer from the engine, stuck stat not letting it circulate.
    Go the stat mate
    Jmac
    Alba European
