Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Chyb swap.
    Jun 2022
    acacia ridge queensland
    Can I get a link to the piggy back ecu?
    The next killer will be getting someone to tune it for you. Alternatively I wonder if anyone could map the factory ecu with a tune for a tsi? Then there would be no need to run a piggy back ecu.
    Jun 2022
    FYI the auto polo that I'm watching on Mannheim is already up to $2500 and it's online for 2 weeks so once it's sold I think it will be around $5-6000. So importing the gti set up is viable option if you can land it all for $3500
    Nov 2007
    Quote Originally Posted by kristianvanek View Post
    If you are looking at the Repairable write-off auto 85TSIs, then yes they will go for $5-7K. This is because they can be repaired and sold again. The value of those once fixed would be $11-12K.
    What you need to find is a manual Statutory write-off that can only be used for spares. They will go for $2.5-$3.5K and as I mentioned will include everything you will need for the conversion + extras. Far better than bits from overseas.
    Jun 2022
    Finding a stat write off will be a waiting game.
    Nov 2007
    Stat-write off Polos pop up quite often, its the manuals that are hard to find. Luckily the manuals are also cheaper usually ....
    Last time the perfect 1 was available, I had a Mini taking up the space I needed. Space is free now
    Pickles btw, is much better than Mannheim IMO.
