Page 52 of 94 FirstFirst ... 242505152535462 ... LastLast
Results 511 to 520 of 936
Thread: It Begins: The S3 1.8T into my '85 Mk2 GTI
  1. #511
    Aug 2009
    Your wife/girlfriend knows what a turbo is? That's awesome!
  2. #512
    Dec 2007
    Perth, WA. *YAWN*...
    Hahahaha! Yea only cozI'm constantly boring the crap out of her with 'car talk'!!
  3. #513
    Dec 2007
    Grant came round and helped bleed the brakes so its drivable now.
    Took it to work this morning (only 5 mins away) to get a quote for an exhaust system and map check and got to fang it once or twice. Acceleration is like being bashed in the guts with a medicine ball
    Much fun and demerit points is upon us comrades
  4. #514
    Feb 2007
    Perth, WA
    To quote the girl in the vid: HOORAHHH!!!
    It sounds a lot like my dads turbo diesel hilux, not bad for a 1.8t!
  5. #515
    Aug 2007
    Perth WA
    Quote Originally Posted by GOLFBALLS View Post
    w00t w00t!!
    '04 BMP MkIV R32 #144
    search getnew
  6. #516
    Dec 2007
    This morning I had a little time to check over a couple of things. The left rear tyre almost rubbed thru so i've raised the rear end up about 15mm and folded up the inner arches a bit. That seems to have stopped the rubbing! There was bloody tyre smoke coming from the arch as i was driving along before!!!
    There are a few little problems to address though. Those supposed G60 heavy mounts from GSF are not firm enough. I should've known not to buy cheap crap from them. It's proof that you really can't cut costs with those sorts of things.
    There's only so much I can shave off that master cyl and the timing belt cover is bumping against it when its loaded up under acceleration. It's even cracked the plastic although I checked the belt and there is no sign of rubbing... yet.
    There's also something funny happening with the voltage to the left headlight as it's faint, and there's something loose in the drivers front strut top mount as it's knocking and rattling over little bumps.
    Next week i'll get an exhaust on it and have them hook it up to a wide band A/F ratio meter for a mixture check, get a fan on the rad, and back up to golfwagen to sort the mounts and suspension rattle...
  7. #517
    Dec 2007
    Ok so final chapters approaching now. Its booked in at RPW on wednesday for the cat back (in mild steel for now) and to then hook up the wideband to make sure the fuel mixture is ok.
    i'll put up some pics soon.
  8. #518
    Sep 2006
    Australia?
    Great news wade, keep up that motivation mate
  9. #519
    Jun 2007
    Eastern Suburbs Melbourne
    excellent news!
    Time for some videos!
    i like volkswagens
  10. #520
    Jan 2008
    Canning Vale, Perth, WA
    what on earth are you putting an exhaust on it for?
    don't you (or the cops) like the 'tractor' sound? LOL
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
