Page 37 of 94 FirstFirst ... 2735363738394787 ... LastLast
Results 361 to 370 of 936
Thread: It Begins: The S3 1.8T into my '85 Mk2 GTI
  1. #361
    Jan 2008
    Canning Vale, Perth, WA
    did the videoing work out well Wade?
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
  2. #362
    Dec 2007
    Perth, WA. *YAWN*...
    Quote Originally Posted by gareth_oau View Post
    Yea mate, thanks again for tha it was really helpful, and the test drive of your S3!!
  3. #363
    Jan 2008
    you're most welcome Wade, hopefully yours will be running like mine soon enough!!
  4. #364
    Dec 2007
    Bit of an update.
    Got the engine harness on the other day. Just one or two plugs from the old loom left to put together. Also mocked up the breather tubes etc for the boost control system. Just two broken pipes to replace.
    While I was installling the QPE harness, I noticed this temp sensor which runs to the turbo. Not sure what its exact function is. The plug for it was part of the other loom that is not needed for this conversion but I cut the wire not thinking, and I'm hoping there will be no problem without it.
    I removed it from under the intake manifold to install the MAP sensor in its place.
    I have another question if anyone can help: The diverter valve has that small tube coming out the top which normally connects to the N249. But all of that throttle purge/emissions/evap stuff is being deleted so the small tube now has nowhere to go! Can I blank off the little nozzle, leave it open, or run a tube somewhere else?
    Here's the wiring going on
    Still need to get hold of an 02A starter and mk2 G60 radiator. ANYONE????
  5. #365
    Dec 2008
    Baldivis, WA
    The little nozzle on top of the diverter valve connects to a vacuum hose from the inlet manifold so that excess air can be dumped when you lift you foot of the accelerator pedal.
    '81 MK1 Golf GTI
    '15 VW Golf R Wolfie
  6. #366
    Dec 2007
    Well, the last week or so I've been pushing the tough-as-nails temporary Cordoba runner to the limit with a leaky radiator and I let it get very hot a couple of times.
    Today I paid the ultimate price. On the way down to roccodingo's to get some bits for the 20vt I started hearing what initially sounded like loud pinging as i was going thru the tunnel. I thought "oh it's just that semi loose fan cowling rattling". Then it got louder. "oh its pinging coz its a bit hot" - no its actually ok temp wise. Hmmm...
    Got down to orrong rd and it was evident something serious was letting go as there seemed to be a rocking chair in a tumble dryer under the bonnet, and I was losing power.
    Made it to the lights about 2mins from Grants place but they were red, and the racket from the engine ground to a smoking halt!
    Towed it down the road and now I'm driving Grants son's old mk1. Thanks Grant, you're a champ!!
    But thats about $1300 down the tube and a major PITA.
    Oh well, I figure i can spend more money and time changing the engine, or just hurry up and finish the mk2.
    SIGH...
  7. #367
    Perth. WA
    Hopefully the red POS got you home in one piece without itself detonating ( its in line for dismemberment, rotted beyond repair..) We still need to get a starter motor yet !!
    OK, all the closet hoarders of O2A starters come out with the goods !!!
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  8. #368
    Jan 2008
    Newcastle, NSW
    Almost there mate! Hopefully not too many dramas sourcing the startar and G60 rad
  9. #369
    Jan 2008
    Wade, if I go to my car one day and find the starter motor missing, I'll know where to come looking!!!
  10. #370
    Perth. WA
    wade, GS&F are doing starters for 65 quid...the killer is going to be the freight...( ask Gareth !!)
    ( 901VG0480 STARTER MOTOR CO 4 Cyl Manual >7/91 65.00 )
    Cheers,
    Grant...
