Brief update.
Got the shifter in. The cable shifts base is narrower and longer than the original, so I drilled some holes, used those threaded rivet things for the two rear bolt holes, and I could get a spanner in the top for the fronts so just used a locking nut on the top. Also used the existing bolt holes too as the bolt shoulder covers the edge for extra support.
Here's a few shots test fitting the QPeng downpipe. Sexy
