Page 35 of 94 FirstFirst ... 2533343536374585 ... LastLast
Results 341 to 350 of 936
Thread: It Begins: The S3 1.8T into my '85 Mk2 GTI
  1. #341
    Dec 2007
    Perth, WA. *YAWN*...
    Quote Originally Posted by gareth_oau View Post
    being crushed? I'm hoping if there is a risk that you work with axle stands or ramops or something safe
    Axle stands. But possibly can be knocked over by my fitting.
    Aaanyway, one of my next jobs is to go over all the hoses and pipes on the AMK that are still needed in the swap and see what i have to get. Some of the bits were destroyed in the shunt. Once i get an idea of what's what, i'll give you a buzz mate.
  2. #342
    Feb 2007
    Perth, WA
    SAMCO hose kit, doooo iiiiiiiittt
  3. #343
    Dec 2007
    Yea one day, if they make one for this conversion??
    Anyway we all love pics...
    Getting crossmember bushes in with lube, bolts, washers, strut tops, and lots of swearing!
    Job done!
    New serpentine belt & tensioner
    Getting box & engine lined up for holy matrimony.
    Hoisting in to posissshh..
  4. #344
    Dec 2007
    Crossmember JUST clears p/s pump outlets!!
    Master cyl JUST clears timing belt cover!!!
    And here it is!!
    It was such a mission doing it all on my own, but REEAALLLY satisfying now.
    Still got a ways to go obviously, but home stretch now! YYAYYYY!
  5. #345
    Nov 2009
    Hobart, Tasmania
    Fantastic work! Looks like everything fitted just perfectly!
  6. #346
    Dec 2008
    Perth
    awesome wade! Must be very satisfying stepping back and taking that photo
  7. #347
    Aug 2005
    Prahran, Vic
    fits like a glove.
    those bushes sound like a major PITA. must be damn satisfying once their in though..!
  8. #348
    Dec 2007
    Quote Originally Posted by joshyd-mk2gti View Post
    fits like a glove.
    Dude, it's like major constipation ending with four big satisfying nuggets coming out!!!!!!!!
    It took a week getting one in, then i changed my technique using a small lever bar and "POP" in the last three went within 5mins.
    And yea Dan, such a satisfying photo!
    But, its all gotta go yet. Next up is:
    1. install remaining g'box bolts - DONE
    2. find starter motor to fit g'box!! - DONE
    3. install clutch cable - DONE
    4. install speedo cable - DONE
    5. find longer throttle cable & install - DONE
    6. Mount gearshifter - DONE
    7. install S3 fuel pump insert to mk2 housing (if possible!) - otherwise mk3 tank swap
    8. sort thru AMK hoses & pipes and see what can be removed/retained. Some of those bits are busted so i may need to order new bits. - DONE
    9. Connect QPEng wiring harness & ECU (and find out if my immobiliser needs to be disconnected for it to run) - DONE
    10. get 'speedy sleeve' put on corroded drive shaft flange - DONE
    11. Fill engine & g'box with oil - DONE
    12. buy a dipstick! - DONE
    13. fit & plumb radiator
    14. install intercooler and fabricate charge piping. - DONE
    15. new wheel bearings in - DONE
    16. Install G60 hubs & 280mm brakes - DONE
    17. install KW V2's - DONE
    Phew! Really?? That much still?! Oh sweet jeebus
  9. #349
    Camden, Sydney
    Looking good mate.
    My master cylinder is a similar fit, makes to keep decent mounts on the engine though!!
    If you were to put a couple of spacers under the front subframe and used longer bolts, it will give you a couple of mm more on the master.
    Good luck with the plumbing, my setup is pretty unique.
    Keep up the progress reports.
  10. #350
    Dec 2007
    Looking good mate.
    Yea will do mate. I noticed the QPEng guys shaved the end of master cyl for clearance!!
