Page 34 of 94 FirstFirst ... 2432333435364484 ... LastLast
Results 331 to 340 of 936
Thread: It Begins: The S3 1.8T into my '85 Mk2 GTI
  1. #331
    Dec 2007
    Perth, WA. *YAWN*...
    Good Work! glad to see you're really getting stuck in!
    Did you use a 16V tensioner for the timing belt??
    Cheers.
    Used the the standard tensioner.
  2. #332
    Feb 2006
    Melborune, VIC
    Those front crossmember bushes are a real bastard. I gave up on the poly ones and went back to new OEM rubber bushes.
  3. #333
    Camden, Sydney
    All looks good Wade.
    I cant help thinking that if you used a Mk3 or SEAT subframe, that would give you the later kind of cups for the engine mounts and you could use VR6 or uprated VR6 ones.
    It will probably be fine.
    I wanna see a pic of it all bolted in.
    Keep up the good work.
  4. #334
    Dec 2007
    You may have a point, but it has to go the way it is now. It'll be fine either way.
    Just had a major win with the crossmember bushes!!!!!!!!!!
    Just putting it together now, which will be followed by the engine and gearbox union, followed by installation!
  5. #335
    Dec 2007
    Is it in yet?
    Stayed at the shop till 1am this morning till i was about to have a siezure (i'm epileptic).
    The gearbox and engine are together, both bolted to subframe/mounts, hoisted up and bolted up to car with front crossmember in place!! WWWOOOOOOOOOOOO HHOOOOOOOOOOOOOOOOO! After 3 years it was awesome to see it all go together so drama free. Preparation pays off.
    Still need to just align the steering column before i bolt up the drivers side subframe bolts then add the rest of the gearbox bolts.
    My next costly snag is sourcing a starter motor. Will have to find a wrecked T4 somewhere... oh yea and fill the gearbox with oil!
    It looks the sex in the bay all shiny and turbocharged pics on saturday
  6. #336
    Jan 2008
    Canning Vale, Perth, WA
    hehe Wade, wouldn't being epileptic help you do up the bolts a lot quicker?
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
  7. #337
    Dec 2007
    Quote Originally Posted by gareth_oau View Post
    In theory no - being that i'm unconcious during a siezure, BUUT, it did help as i was rushing to get it together before i started the uncontrollable breakdance!
    The fear of being crushed under a car during a fit was inspirational!! I didnt end up with a fit, but i was prepared to go thru it to get that donk in by the end of the day.
  8. #338
    Feb 2007
    Perth, WA
    WOOHOO!!! Great to hear your making big progress now wade
    May I recommend Motul GEAR FF-LSD TYPE 2 gearbox oil? It is very good stuff, I have some in my vr6 - very smooth shifts!
  9. #339
    Jan 2008
    being crushed? I'm hoping if there is a risk that you work with axle stands or ramops or something safe
  10. #340
    Jan 2008
    oh, and when you coming round to get that thingamejig?
