Page 33 of 94 FirstFirst ... 2331323334354383 ... LastLast
Results 321 to 330 of 936
Thread: It Begins: The S3 1.8T into my '85 Mk2 GTI
  1. #321
    Dec 2007
    Perth, WA. *YAWN*...
    Quote Originally Posted by peedman View Post
    Hey wade do u still have any parts left over from the s3??
    A few bits and pieces. What you after?
  2. #322
    Oct 2006
    Quote Originally Posted by GOLFBALLS View Post
    Have u got a headlight switch or an armrest???
  3. #323
    Dec 2007
    Niether sorry.
    Got stuff like dashboard, glovebox, wiper arms & motor (will fit golf 4), drivers side rear popout window, various door mechanism bits, etc.
  4. #324
    Oct 2006
    ah darn thanks anyway tho. fyi the s3 has a different headlight switch to the a3's due to the xenons and self leveling. fact it is, whether its any use to u, prob not lol.
    if i need anything from the dash ill let u know. i can swap u a mk2 manual adjust clutch cable if need be
  5. #325
    Dec 2007
    Ok, so it's update time and pics!!
    Cleaned up the engine bay. It's not perfect, but this car aint gonna be no trailer bitch! It's gonna be a daily, and thats clean enough for me.
    G60 mounts in (thanks Tim at Dubaddiction)
    Getting out the old control arm bushes. Horrible.
  6. #326
    Dec 2007
    Cross member bushes out. Still trying to get the bastard poly ones in!!
    Getting a bit creative putting in control arm poly bushes. More horrible!
    After...
    Old vs new G60 g'box mount
    Same again for front eng mounts
    And rear...
  7. #327
    Dec 2007
    02A Corrado/Ibiza Cupra/Passat/T4 gearbox brackets. (thanks loon)
    Installed... Also note mechanical SEAT clutch lever
    Gearshifter out ready for cable replacement
    Mk2 p/s pump bolted up to 20vt bracket and mk4 pulley.
    Machined 228mm flywheel, all torqued up WITH cover plate behind!!!
    VR6 clutch together
  8. #328
    Dec 2007
    Thought while engine is out and i'm already broke, might as well do timing belt!
    Old plastic vs new metal waterpump
    Installed including belt, waterpump, tensioner and damper.
    Still going strong after many late nights and confusion, but i'm on the home stretch now. My girlfriend hates this project!!
    Engine will be in by the weekend then the plumbing begins!
  9. #329
    you sir are a champion
    keep up the good work fella!
  10. #330
    Jun 2007
    Eastern Suburbs Melbourne
    Good Work! glad to see you're really getting stuck in!
    Did you use a 16V tensioner for the timing belt??
    i like volkswagens
