Page 84 of 94 FirstFirst ... 34748283848586 ... LastLast
Results 831 to 840 of 936
Thread: It Begins: The S3 1.8T into my '85 Mk2 GTI
  1. #831
    Dec 2007
    Perth, WA. *YAWN*...
    Love that even with all the work you've done there's always something more to do.
    You're putting 260 hp through the front wheels which is the absolute limit for FWD. What's it like to drive?
    Its tame enough if you're just putting around town not really on boost, but if you mash the loud pedal you need to hold the wheel to keep it straight!!
    Its got zero traction in the wet...
    But it's really up to how you pedal the thing as to the driving experience it returns to you.
  2. #832
    Apr 2010
    City of Swan, WA
    Quote Originally Posted by GOLFBALLS View Post
    Finally, it's all legal.
    For anyone looking at doing this, its not as daunting as it seems.
    Step 1: Download 'Application to modify passenger vehicle' form from DoT website & fill it out & send it back.
    Step 2: wait for them to send you an approval pending an engineer's report. (they may ask for more info on some of your planned mods).
    Step 3: Finish all your work. Like, actually finish it. Properly.
    Step 4: Take it to a certified engineer to look over. Give them a copy of your application form and as much spec info on the car prior, as well as after the mods. (weigh bridge receipt, height, track, decibel reading of exhaust, speedo check, brake test, etc). They'll then take photos and using the info you provide write up their report and send it of to DoT. Usually, if there's anything they aren't satisfied with they'll just tell you to fix it up and come back.
    Step 5: Wait for the final approval in the mail from DoT. Once it's arrived, book the car in to a certified licensing inspector ('pits') to check it over and give you your piece of paper!!
    On step 5, i would highly recommend using a private vehicle inspector. The transport dept ones are generally arseholes.
    Then you'll just need to take it in to get the details changed for your rego papers!
    You're welcome
    Noice!
    Got Turbo Inside
  3. #833
    Dec 2007
    it was a strange mix of feelings...
  4. #834
    Dec 2007
    Just some of the old messy wiring i cut away.
  5. #835
    OK, I know power to weight is important for hillclimbing but this is taking it a bit too far!
  6. #836
    Jun 2007
    Eastern Suburbs Melbourne
    respray?
    i like volkswagens
  7. #837
    Perth. WA
    Send the old bit of harness down to me thanks Wade, Make sure your taking plenty of pics
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  8. #838
    Dec 2007
    The caramel wheel made short work of the GTI hatch decal
  9. #839
    Dec 2007
  10. #840
    Dec 2007
    respray?
    Oh, yes!
