Here's the PCV/breather crap removal.
All this is gone!
And replaced with this...
Apologies for the crud pics. iPhone camera hates the dark!
So basically the rocker cover and crank breather are now just going directly to the new catch can. It fit neatly in the housing and place of the old charcoal canister!
I had to blank off one outlet in the middle of the manifold, and run the brake booster line directly into the end of the manifold. I also blanked the hole in the intake trunk that used to inhale all the warm, oil vapoury air from the pcv/rocker cover.
Apart from that, all the stupid joins, lines, check valves, suction jet and pcv is GONE. There's about 6 fewer vacuum leaks to worry about!!!
