Why not take this opportunity to bypass the ignition switch and run a separate +ve wire to the ECU via a hidden switch in the cabin. Run it to a +ve connection that only gets power when the ignition is on (make sure it's fused). That way if you leave the car with a mechanic you can leave the ECU switched on because it will only come on with the ignition turned on. When you park at work/home/naughty ladies club you hit the switch and no-one can drive off in your car.
I had a push on / push off switch mounted in the foam padding under the top of the dash. You couldn't see it but you could feel it if you knew it was there.
If you decide to produce this commercially and make millions I want 50%.
Paul
