Tinto, check gumtree perth, there's a mk4 gti being wrecked at maddington few days ago.
Where does a chap start looking for a 1.8T + Gbox (or a VR6 engine & box for that matter) in Perth?
I'm searching online, but realise that this is the sort of thing that is possibly sitting on a palette at a wrecker rather than written up and photographed.
Yours came from a wrecked S3, is that right Wade? is the gearbox from that too - just disconnect the rear shaft or something?
Not sure my wife (or neighbours for that matter) would be too pleased if I skull-dragged a wreck onto the front lawn, so I think I need to keep it a fairly compact arrangement.
Got Turbo Inside
I must be blind or searching on the wrong terms - thanks for the tip Rutti!
Yep just call some wreckers.
Perth Spare Parts have one. Call Alex on 9451 1444. They're in Beckenham. Tell them i referred you.
I personally wouldn't go the VR6 route. Too old, unreliable, complex and heavy.
I also used the Corrado 16v gearbox. Have a look back towards the beginning of this thread its all there.
Or, go to the QPEng website. There's a whole guide there which is a great start. Otherwise, a standard mk2 box will be good up to 160hp..
Come see me, 2 x 1.8T engines, O2J and O2M trans sitting in the shed Also the source of Wade's O2A trans.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Put in some solid time yesterday.
As a result i didn't spend too much time taking photos, but here's a few.
All the doors are glassed and rubbered. Got some nice clean glass and some of the rubbers are brand new.
The black GTI hatch decal didn't really fit well so i had to slice it so it would fold down. It was a biatch to get straight.
The window seal covers up the cuts.
Then came the wiring. I hated the old harness tubing. It was hard and dirty and clumsy. So i got into sorting it out, cutting it off and bought some corrugated tubing.
It looked great all done but i forgot to take a photo. Will do later.
teaser....
Looking mighty fine.
Did you do anything to the engine while you had it out?
'04 BMP MkIV R32 #144
search getnew
