Page 17 of 94 FirstFirst ... 715161718192767 ... LastLast
Results 161 to 170 of 936
Thread: It Begins: The S3 1.8T into my '85 Mk2 GTI
  1. #161
    Perth. WA
    Mmmmm...
    take it to turbo tech and get them to check it out, maybe just need minor work to rectify it, but leave it and it has the possibility of causing major grief...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  2. #162
    Dec 2007
    Perth, WA. *YAWN*...
    mmm yea good point might do i think. It's not much of a scrape really and only on that one spot. There is about 0.5mm of play (side to side) if i really give it a firm wobble and then it just rubs on the side but still turns.
    Sounds quite possible it could be the heat expansion thing as Gavin mentioned?
    The foreman at Audi Centre Perth said some of these have lots of play in the turbine shaft. He's seen Q7 TDI turbo's with almost 1mm of movement in the turbine!! Well, i assume that's a lot anyway.
    But this turbo business is pretty new to me still and i'm learnin as i go, so to be safe i'll get it checked by a specialist.
    Thanks lads
    I'll let ya'll know what the deal is as soon as i know!
  3. #163
    Aug 2005
    I wouldn't worry about that - I have two new Garretts here and both of them have a fraction of rubbing against the housing Once the wheel is at full speed, it'll centre itself and won't rub anyway.
  4. #164
    Camden, Sydney
    Yeah they have a fair bit of play when idle.
  5. #165
    Gosford Central Coast NSW
    once oil is forcing its way through the bearing case under pressure, it centers the shaft - one of the reasons you need a tip top oil system for a turbo engine.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  6. #166
    Dec 2007
    Lsd Goodness
    Got the Peloquin! YEAH!!! Check it. The "instructions" on installing were sooo crappy tho Looked like it had been written by an illiterate 7yo
    MMMMM the smell of traction......
  7. #167
    Jan 2008
    Canning Vale, Perth, WA
    good buy - how much did a peloquin set you back?
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
  8. #168
    Dec 2007
    Twas the princely sum of around $1300AUD landed at my doorstep. thescirocco.com
  9. #169
    Jan 2008
    well done! and i bet you paid for that before the A$ crashed!!
  10. #170
    Jan 2008
    Melbun
    that looks like a torsen type diff is that right?
    2x Caddy, 1x Ducato
