no wazzas alex! hopefully next time ill see ya at SEDF
ok finally got around to take some sump action shots, a notch will make it on the ground
fuuuuuu... so sick!!!
That's awesome mate,
I just came across a 2nd hand air ride kit for a B4. http://www.edition38.com/forums/inde...&#entry2616065
It would just be too much to have two Passats on bags. One's enough!!
Ha bloody hell. You've done well.
Dare I say, space the wheels outwards a bit for more flushness? I know it's not what you're going for, but it would aid the dopeness levels.
That, and euro rego plates will top it off.
Congratulations man. I'll look forward to checking out at the next meet.
its so much better in person.
MK1 GLS 3door
A4 B7 2.0T
get that notch happening dom, plenty of room till you hit the deck!!
From the outside pics it still has a bit of movement before the body hits the ground when its bagged out.
So what can you do to get around the sump?
Is it possible to fit a longer/wider sump that is shorter allowing a greater drop?
Or are you just going to leave the stock sump and sit it a bit higher than ground level for the bodywork?
ummm! no ****ing way! u get that ****!! ill help you install it!!
that is ALOT more harder than you think, im tucking well over an inch or rim, and its as close as 2mm away from the guard's some times even paper thin, i built the car to tuck all 4 rims! (not just tyres) and im very close in doing so, a spacer is well out of the question
hahahah cheers buddy
yeah ill be getting it up on a 4post hoist this weekend to check for exact clearances and where the driveshaft hits then ill mark it all and get crackin, i still have to run the gauges through to the cabin this weekend
dom
congrats Dom! Big effort and persistance there and it's finally paid off! wickedand for my 2c of eff all, I think you need to work on your stance bro, it's got the low but has no stance to it, work the rims, get'em wider or space'em with camber and I reckon some mirror deletes would look tits!
Keep at it, it's things like this that's going to push aus dubs further!![]()
