****ing time dude! I seriously need to post the video we made with your sub on here haha.
seriously.... ABOUT ****ING TIME! lolAndrew@OpenRoad (9:57 AM 2-15-2010): your package went out today at lunch with DHL. expect arrival at the end of the week.
picking up my fittings tomorrow too, looks like its going to be a busy weekend for me!!
dom
Yes yes! Do eeeet!
Hahaha. Can you edit out our stupid laughs?![]()
dun dun duuuunnn!
recieved my rear bags this morning, then straight after that it was time to pick up all the valves and fittings, i got to the air ride shop and had a chat with michael, pointed me in the right direction with fitting the valves ect, then asked if i have all the switchbox wiring, i said no, then he came out with this insane loom! it just plugs into the regulators on the valves and all you do is plug them into the switchbox!! so i had to buy that too!!
anyways pics
and the setup of my valves (need to build another row)
going to build my valves and make sure everything fits in the spare wheel well, then ill get cracking and pull the car apart this weekend!!
dom
Someone's a happy boy![]()
Finally everything is ready to be built.
Can't wait to see the outcome of this!
cheers dude! ill be making this a step by step sort picture thread so stay tuned
ill talk everyone through the valves that are temp built
ok, starting from left to right:
this is 1 row of valves, they could control either front or rear of the car, 2 valves per wheel, the outer valves, far left-far right and dump valves, the control the air out from each bag, in the middle you have a big T fitting, that is connected to the air tank with some hose, the air is pumped into that T fitting and then pushed into the 2 middle valves. they control air INTO the air bags, that air then gets pushed into the little nipples you see in between the IN and OUT valves, a hose is connected to that nipple and to the airbag's, also take note of the little 90deg nipples facing the camera, they are 1/4" fittings and are connected to the gauges and give me a air pressure reading inside the car. now.... all this is controlled by the black boxes on top of the valves, the wiring loom gets plugged into the valves, then plugged into the color matched switch-box wires, hence! power to control the valves going up and down! YAY!
hope you guys can understand it
dom
does that mean it'll go up and down? lol
hurry the f up and install it seriously haha
hells yea. About time bro. pity I'm flat out this weekend![]()
