Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 138
Thread: APR Tuned Candy White Golf 6 R from South Africa
  1. #121
    Jan 2010
    Melb Westsideeeee
    Wow mate, excellent progress! You look after the car damn well too haha. Very impressed, keep it up!
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  2. #122
    Mar 2013
    Bethlehem, South Africa
    Update.
    So Dragwars happened this weekend...
    Took the 300km drive up to Pretoria to spend the weekend at a friend's. No trailer options for me coming from far.
    Pit Stop at a petrol station in JHB
    The following day I went through to my APR dealer to collect my APR dongle and prep the car for Tarlton. Rey from Experience sent Malcolm the HPA tool and the file for my Stage 3 DSG flash.
    Malcolm requested we log the car which we did. Car's shifts are still quick like before. Could feel a few adaption shifts. Seems to clamp down better in higher gears, but still slipping slightly on the 98 file. Unfortunately I will have to upgrade the packs before attempting the 104 file.
    So I switched to the 98 file which is basically a UK and Australian pump file to use for Tarlton.
    Here are pics of my car at Tarlton. Some are courtesy of Krutch and VAG Motorsport
    Later in the day, about 30 minutes before the track closed, Laven told me to fit his slicks and have a run. Unfortunately I only managed one run and the track was closed. Being my first time with slicks, I didn't realize I need to launch the car a bit to try heat the Hoosiers up. Car wheelspun off the line, and when it grabbed it just kept going. On the run with the slicks I managed a 12.13s pass.
    In 36 degrees heat, I still managed a personal best of 11.98s pass with an exit speed of 185.7km/h. This was with my full street trim, 19" OZ wheels and Yokohama street rubber. I was on full OEM interior, rear seats and battery. Only thing stripped from my car was the spare. Track conditions were excessively hot and every competitor complained about that. So for now I am happy as I have reached the 11s.
    Next up.... I will have to look at upgraded clutches so I can run the 104 file. And definitely a set of 17s with slicks. (And some practice on using them)
    Here is my time slip:
    And here are the video runs:
    https://youtu.be/aavQ6Ez_vjs
    2012 Candy White Golf 6 R DSG - APR Stage 3
    460BHP/344Kw and 608Nm
  3. #123
    I'm old enough to remember when, back in the 70's, there were only a handfull of cars in Australia capable of running 11's. Street Machine magazine used to do a full article on each car when it broke into the 11's because it was so rare and the cars were really wild V8 machines.
    For you to do it with a 2 litre, running full trim on street tyres may be more common nowadays but it still doesn't take away the fact that you are now the proud owner of a 11 second car! Well done.
  4. #124
    Mar 2013
    I managed to source a set of OEM VW R Recaros. Made a swop with a fellow R owner along with a cash difference.
    The last pic of the stock seats...
    OEM Recaro Seats installed...
    Got myself some R logo seat inserts.
  5. #125
    brisbane
    Mar 2013
    And over the Month End weekend I stopped at the Mall with the fiancé. As usual I stop on the other side of the mall where nobody stops cause I don't want other people's car's door dents on my R.
    A local friend following my R build stopped next to me with his fairly new Mk7 R. Thought it was a good idea to take a few snaps... Everyone claims the Mk6 looks so dated to the Mk7. I just can't fault my Mk6. Maybe cause it's modded to stand out. For the money I've spent on my R, I don't see myself trading this car of mine in on a Mk7 anytime soon. Regardless of their awesome potential and how awesome those Pretoria wheels look.
  7. #127
    Prefer yours over the MK7 any day.
  8. #128
    Mar 2013
    Had my R at our local Wheel Alignment shop...
    I normally do some chassis inspection on the ramp to make sure everything is ok. Inspect my propshaft couplers, suspension and driveshaft boots.
    So I managed to snap this...
    Gets pretty hot around my GTX turbo's turbine section..
  9. #129
    Mar 2013
    Update on my car. 3500kms later since the move to APR's Stage 3 GTX kit. Still going well with no issues and hiccups so far. And power delivery is still so smooth. I must say that as my R is now, she is perfect. Rolling she has so much life in her. And the driveability of my car is just amazing. My car still feels like a stock turbo R with seriously added grunt when cruising. The Recaros I fitted are a pleasure to sit in. The gear changes seem to have adapted so well with the Stage 3 DSG flash from HPA. Everything just works as a package.
    My 2 piece ECS front brake discs are the only thing putting me off on my car. Just touching the brake pedal and feeling the vibration is the only negative thing on my car right now. They are warped. This is my fault as the EBC pads I used really don't work well with my driving style. The pads need heat to really work and when I really needed to stop and climb on the brakes they would hurt my brake discs. I think the few visits at the drag strips is what hurt them so bad. Cold brakes and climbing on them after crossing the end stretch. I would notice blue splotches or patches on them after runs. So a set of replacement rotors/discs will be here soon. I will also be using a softer pad that has bite initially as I feel the rotors I have provide more than enough cooling. Thought of a big brake kit as well... Would look so cool behind my OZ wheels, but then I can't run lightweight 17s with drag radials. I feel my brake setup (ECS rotors, ECS braided lines, Motul fluid) is more than sufficient for my daily setup.
    Here are some random snaps on the car so far...
    And a great snap taken from Anees. He asked to meet up at the local VW dealership and feel the delivery of my BT Golf R.
  10. #130
    Mar 2013
    And some shots after giving her another good valet yesterday. Auto Finesse products FTW!! Cleaned out everything from interior to engine bay and sealed the paintwork.
