Update.
So Dragwars happened this weekend...
Took the 300km drive up to Pretoria to spend the weekend at a friend's. No trailer options for me coming from far.
Pit Stop at a petrol station in JHB
The following day I went through to my APR dealer to collect my APR dongle and prep the car for Tarlton. Rey from Experience sent Malcolm the HPA tool and the file for my Stage 3 DSG flash.
Malcolm requested we log the car which we did. Car's shifts are still quick like before. Could feel a few adaption shifts. Seems to clamp down better in higher gears, but still slipping slightly on the 98 file. Unfortunately I will have to upgrade the packs before attempting the 104 file.
So I switched to the 98 file which is basically a UK and Australian pump file to use for Tarlton.
Here are pics of my car at Tarlton. Some are courtesy of Krutch and VAG Motorsport
Later in the day, about 30 minutes before the track closed, Laven told me to fit his slicks and have a run. Unfortunately I only managed one run and the track was closed. Being my first time with slicks, I didn't realize I need to launch the car a bit to try heat the Hoosiers up. Car wheelspun off the line, and when it grabbed it just kept going. On the run with the slicks I managed a 12.13s pass.
In 36 degrees heat, I still managed a personal best of 11.98s pass with an exit speed of 185.7km/h. This was with my full street trim, 19" OZ wheels and Yokohama street rubber. I was on full OEM interior, rear seats and battery. Only thing stripped from my car was the spare. Track conditions were excessively hot and every competitor complained about that. So for now I am happy as I have reached the 11s.
Next up.... I will have to look at upgraded clutches so I can run the 104 file. And definitely a set of 17s with slicks. (And some practice on using them)
Here is my time slip:
And here are the video runs:
https://youtu.be/aavQ6Ez_vjs
