update time!
Wheel gap is bad…
Time to get the Golf’s suspension sorted! After browsing around VW Watercooled researching my options, I seemed to keep being pointed into the direction of one person, Robin. Robin is the Australian distributor of HotTuning Coilovers, and the more I looked into it, the more I thought that these would be perfectly suited to my application. The Golf is soley my daily driver, and will never see a racetrack, so I was after something street-friendly at a reasonable price that would still enable me to enjoy the odd twisty road. My main goal was height adjustability, as I’ve given up on spring/shock combo a long time ago after never being able to get my old cars to sit at the height I wanted.
Once I contacted Robin, he was a huge help and answered all of my annoying questions without hesitation. This was especially appreciated as my knowledge of VW’s is not as advanced as say, Nissans. Here’s a run-down on the coilovers from the manufacturer:
The best part was when I found out the price was only $800 AUD delivered thanks to our strong dollar at the moment (compared to last year at the time of the economic crash). I also opted to purchase the swaybar drop-links that are also available, as I knew I’d run into clearance problems after lowering the front end. Just as my luck would have it, they’ve now been reduced to $750 INCLUDING drop links until the end of December. Oh well, you win some, you lose some.
Coilover Specifications:
HOTTUNING coilovers can be raised or lowered, from 20mm to 120mm. All coilover systems include high grade aluminum pillow mounts further enhancing overall control. CNC Wound SAE 9254 Racing Springs are used which were found to be the longest lasting spring on the market that showed no tendencies to sag. Spring and damper rates that yield exceptional handling characteristics coupled with unsurpassed street drivability are used. Extensive Research And Development Went In To Choosing Precisely Matched Spring & Damper Rates Specific To Each Application. The Result Is Outstanding Ride Quality & Incredible Handling Characteristics
So whether you are looking for a great track set up or you need a suspension that adapts to public roads, you have found the right coilover. HOTTUNING , Designed and manufactured for customers who demand the very best!
Summary:
* Superb Overall Control.
* Height can be adjusted without affecting shock stroke length.
* Both Track Abuse As Well As Road Imperfections.
* CNC Wound SAE 9254 Super High Quality Springs.
* Kit includes: 2 front full coilovers, 2 rear full coilovers.
* Sport setup (F=12K – 672 ft/lbs & R=18K 1008 ft/lbs)
2 Year manufacturers warranty
So a few day’s after making my purchase, I had another nice package turn up at work. I waited until I had a free Saturday to install everything.
Here is all the goodies on show. Front coilovers, drop-links, c-spanner, rear perches, rear springs, and rear shocks.
Before installing everything, I thought it would be a good idea to add some sort of protection to the collars, to try to combat the dirt & general under-car conditions that they’ll be faced with. I went to my local hardware store and picked up a grease-based lubricating spray.
I dismantled everything and sprayed all 4 collars, hopefully this will make it easier to adjust them after they’ve been exposed to the elements.
Time to get this party started I guess. I used this write-up as a guide and found it very helpful. I didn’t take pictures every step of the way for two reasons, firstly that write-up has all the pictures you need, and secondly it was a stinking hot day, I had hay-fever, and the beginning of the job was a pain to do.
Front standard suspension. This side was a real pain to remove, make sure you have spring compressors and a big hammer, as the strut assembly is too long to remove otherwise. Once I got past this strut, the rest was fairly easy in comparison.
This is what I used as the spreader tool to open up the strut assembly away from where it sits inside the LCA. It’s actually an assembly tool from a trampoline set!
Adjustable drop-links installed
Now’s probably a good time to work out how the hell you’re going to get to work on Monday, and ask yourself if it’s really a good idea to have two potentially useless cars if things don’t go to plan.
