Page 68 of 94 FirstFirst ... 1858666768697078 ... LastLast
Results 671 to 680 of 937
Thread: Another Wreck, another Race Car.....
  1. #671
    Great video Pete. Nice little spin too!
    What 5th gear are you running, seems very tall!
    The car seems to have plenty of poke, it eats 4rd and 4th gears!!!!!
    Good work fella
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
  2. #672
    Oakleigh VIC
    great video Pete.
    What happened at around 4min mark? did you lift off, or just go in too hot?
    Got carried away trying to see how much faster I could enter the corner.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #673
    Jan 2012
    UK South Wales Europe
    i guessed so pmsl at your above comment, good save though.
    what is the top speed at the moment Peter...mph
    also do you left foot brake, it didn't show up on the graphs?
  4. #674
    Oakleigh VIC
    Quote Originally Posted by velly_16v_cab View Post
    Good work fella
    Agree 5th seems too tall to me too. The gearbox builder was vague about exactly which ratios he put in there.
    It should be a 0.91 or a 0.89 but I'm wondering if it's not a 0.75.
    I'll have to do the math to figure out or just pull the end off the box and count the teeth.
    In any case it's all good input for when I build the 02a down the track.
    7? MK1 Caddy
    12 Amarok
  5. #675
    Apr 2009
    Thats it Pete, im going to say it. You sir, are hands down, a freaking genius. The amount of work that went into that car, and the amount of effort you put into the forums make you an A Grade LEGEND in my books.
    That acceleration is crazy fast. I cant imagine being in it. You over took every single car, and when you spun out you over took them again so effortlessly. I'd like to see that beast in a real race.
    -'75 Passat TS
    -'75 Passat TS (Project)
    No....its not a Piss-sat its a Pass-sat!!
  6. #676
    Oakleigh VIC
    Here's the second timed session.
    The data display runs out about 1/2 way because I accidentally truncated the log data in the conversion process.
    I got warned for being too loud after the first run so for the next 2 runs I short shifted to 5th gear on the main straight.
    The car read 80dB and the limit for that day was 75dB. I'll fix it by fitting an airbox.
    Oh, and yes, I do miss a few gear changes along the way in this round. I think I need to make some adjustments to the shifter.
    7? MK1 Caddy
    12 Amarok
  7. #677
    Oakleigh VIC
    7? MK1 Caddy
    12 Amarok
  8. #678
    Oakleigh VIC
    Quote Originally Posted by fthaimike View Post
    The top speed I've seen so far is just over 180km/h or about 110mph. 5th gear is a limiting factor here. The box builder must have used a 0.75 5th instead of the 0.91 I thought I'd supplied.
    If you look at the RPMs in the videos it's dropping nearly 2500 RPM in 5th which just isn't right.
    Some quick calculations confirm a 0.75 5th but I'll have to explore a little further yet.
    The OBP pedal box isn't that well set up for left foot braking, I need to modify it further to alter the position of the accelerator.
    7? MK1 Caddy
    12 Amarok
  9. #679
    sounds about right with your thoughts on 5th gear, you can even hear how far out it is. Still, it doesnt seem to be slowing you down!!!
    Great comment by Huss, I agree...Pete, great work man. You are a legend!
    Velly
    '91 2.0 8v GTI
  10. #680
    Oakleigh VIC
    Now available in Newsagents across Australia!
    (Mike, I'll send you a copy.)
    7? MK1 Caddy
    12 Amarok
