Page 59 of 94 FirstFirst ... 949575859606169 ... LastLast
Results 581 to 590 of 937
Thread: Another Wreck, another Race Car.....
  1. #581
    Boronia VIC
    The motor was built by EuroSpec for me in the US. Eurospec: High Performance Parts for Audi and Volkswagen
    I had initially approached them for one of their FIA spec crank, rods, and piston sets to go into the ABF motor I've got here.
    It turns out those kits are designed for the shorter blocks and it became rapidily apparent that trying to machine the block in one continent and make parts to go into it in another one wasn't going to work.
    I was trying to negotiate with a head company in the UK for the head work at the time but they just wouldn't respond to ay form of communication.
    Steve (The owner) and Eric from EuroSpec were super helpful and offered me a head they had built as spare for one of their race cars.
    They also had the Jenveys and manifold in the spares cupboard and made me an offer I couldn't refuse.
    After lengthy discussions and much head scratching we settled on the 06A block retro fitted with the ABF 16v head.
    There's many advantages to the 06A including the internal water pump, crank angle sensor and the readily available dry sump system.
    Going with a KR or ABF block would have required a lot of development work to make a dry sump system.
    I'm not sure what the final output will be, conservatively 250HP, optimistically 300Hp. It's really tough to say until I get it on the Dyno after running it in.
    Here's the vital stats,
    O6A block with ABF 16v head.
    Bore 84mm
    Stroke 90mm
    Capacity 1995cc
    Combustion chamber volume: 48cc
    13.5:1 compression
    Valve size: 34x28.5
    Tungsten Valve seats with 5 angles
    Bearings were molly coated and baked before installation
    The cams are from CAT cams and run on solid lifters.
    CAMSHAFT PARTNR. : 7641108
    ENGINE TYPE : VW 16V, KR, ABF
    INLET EXHAUST
    VALVE CLEARANCE (hot) : 0.15 mm 0.15 mm
    (cold) : 0.15 mm (-0,10 / -0,05) 0.15 mm (-0,05 / -0,00)
    CAM LIFT : 12.70 mm 12.15 mm
    ROCKER ARM RATIO : 1.00 1.00
    VALVE LIFT : 12.70 mm 12.15 mm
    DURATION @ 0.1mm Valve lift : 308 ° 294 °
    DURATION @ 1.0mm Valve lift : 270 ° 258 °
    PEAK DIFF.: maxlift @ : 106 ° ATDC 106 ° BTDC
    Valve lift at TDC w/o clearance : 4.72 mm 3.90 mm
    1. w/o clearance at : 0.25 mm valve lift 0.25 mm valve lift
    Valve opens : 49 ° BTDC 73 ° BBDC
    Valve closes : 79 ° ABDC 42 ° ATDC
    2. w/o clearance at : 1.15 mm valve lift 1.15 mm valve lift
    Valve opens : 29 ° BTDC 55 ° BBDC
    Valve closes : 61 ° ABDC 22 ° ATDC
    VALVE SPRINGS
    partnr. : D15009 -
    fitted length : 36 mm - mm
    RETAINERS partnr. : - -
    CAM FOLLOWERS partnr. : CC005 -
    REMARKS : B/A TDC= before/after top dead centre
    B/A BDC= before/after bottom dead centre
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #582
    Boronia VIC
    A few more photos from today.
    I won best MK1/2 modified and best of show modified which was a unexpected surprise.
    I hadn't really considered actually winning a trophy.
    The motor isn't running yet, there's still a little wiring to do and an ECU to program. Then it should be just a matter of adding fluids and firing it up.
    7? MK1 Caddy
    12 Amarok
  3. #583
    Boronia VIC
    A little more detail on the bottom end kit from the EuroSpec website.
    This new stroker kit is based on the FIA kit car specification. With a 90mm stroke by 84 mm bore and using a 150 mm connecting rod, this configuration delivers the best balance of bore and stroke on an 88 mm bore center, while still maintaining a connecting rod ratio of 1.67:1. Consisting of an all new super light Eurospec 4340 forged crankshaft with a 46 mm rod journals, Eurospec 4340 H beam connecting rods with Forged JE’s on a 19 mm pin. Including main bearings, rod bearings and a steel head gasket at the very affordable price of $2,250.00. Available for all two, four and five valve configurations and in compression ratios from 8.5:1 to 13.5:1.
    7? MK1 Caddy
    12 Amarok
  4. #584
    Jun 2007
    Eastern Suburbs Melbourne
    Car looked great yesterday Pete, Congrats on getting it together and getting it there! (Which i'm sure wouldn't have been a problem in the rokamei!)
    Looking forward to seeing/hearing it fired up, and blasting around the track!
    Congrats on the trohpies as well, well deserved.
    i like volkswagens
  5. #585
    Jul 2009
    Geelong, Victoria
    congrats on the awards, well deserved
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
  6. #586
    Jan 2012
    UK South Wales Europe
    Nice one Peter, some great updates, looking much better with our decals on now hope your happy with them.
    Pop some fotos over to Uwe for us if you get a chance mate.
    Another unique kamei golf, each one built so far much different to the last. welcome to our small owners club
    What were the pics you had on display?
    Mike
    fthaimike@hotmail.com
  7. #587
    Boronia VIC
    The display pics were just a random sample of build, I tried to focus on stuff that you couldn't see on the (almost) completed car.
    There were a few shots of the original I'd been using for the placing of the decals, but nothing you haven't already got.
    I did have a few of the Kamei models on display too but didn't manage to take any photos of them.
    I'll write to Mike Wright and thank him again for sending the decals over, I've put his company stickers on the A pillar roll bar at the base of the windscreen. You can just make them out in some of the photos above.
    I'll send some photos to Uwe too. The VW club interviewed me for a DVD they're producing of the event I'll send one of those over too as soon as they're published.
    I've got to get around to updating the thread at ClubGTI too, I've been so busy prepping this I haven't had much time in front of the PC.
    I've still got to sort out the spoiler and trim the front arches a little before it's all done. I was approached by a chap at the show who's keen to help me out with that so with a bit of luck we're not far off finished.
    I've just got word my oil has arrived at Bursons, if I organise some fuel for this weekend I'll be real close to firing it up.
    Hmmmmm, must write to EuroSpec too and check a last couple of details with them before firing it.
    The way I explained the build for the DVD is that this build is how I think the car would have been built with the sorts of engine and motorsport technology available today.
    7? MK1 Caddy
    12 Amarok
  8. #588
    Jan 2012
    good man, oh regarding the other site updating sadly you wont see me on there now so use my email above if you need me.
  9. #589
    Boronia VIC
    Wiring is complete now. All the fluids are in and any leaks sorted.
    It took 9 litres of oil and 7 litres of coolant.
    Just programming now.
    I've put away the crimpers and busted out the Oscilloscope and the laptop.
    Just about ready to make some noise.
    7? MK1 Caddy
    12 Amarok
  10. #590
    Boronia VIC
    These DTA ECUs are pretty neat.
    There's diagnostics to help you setup the sensors.
    Here's the trace on the crank and cam angle sensors.
    I'm using the stock 60-2 wheel and VR sensor from the 06A block.
    Hence the blue lines indicating 2 missing teeth 58 teeth apart.
    Pink lines are the distributor signals.
    Still a bit of head scratching to figure out the offset between the crank angle sensor and the crank itself, but I think I can figure it out with a timing light.
    7? MK1 Caddy
    12 Amarok
