awesome thread , great pics, that shot on the jack is amazing - rigid car for sure!
Just a few more.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
Great work Pete.
Can't wait till Sunday!
Give us a hoy if you need a hand!
Amazing work Pete!!
Gotta love a big red 'engine start' button!
really looking forward to seeing this on Sunday Pete! Looking amazing
Looking great there Pete, cant be far from blast off !!
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Very close now, it's mainly together.
Still a few wires to run in and terminate.
There's still programming and debugging to do on the ECU, data logger and dash yet, that'll take me a little while to nut out and document.
I need to have the dash talking to the ECU before I start it so I can see oil pressure and temperatures.
I also need to have the brake pressure sensors reporting to the dash so I can set the initial bias.
I've filled the brake system with AP PRF 660 fluid and had two small leaks to sort out.
(I took the cheaper option and used regular Castrol super DOT4 fluid in the clutch system.)
One leak was a brake light switch which was easily sorted and I've just spotted a weeping union in one of the rear lines, that'll just need nipping up.
I don't think I'll get the front spoiler done for DOVW at this rate, I'm just running out of time.
Hanging the doors and guards won't take too long, they've been on and off the car a lot of times now.
There's a few little touch ups to do to the paint here and there.
7? MK1 Caddy
12 Amarok
This is the layout of the control panel.
I've avoided indicator lights because I intend to operate this by touch.
The only buttons I'm likely to need mid-flight are the wipers and kill switch so I put those where I can find them easily.
Most other controls are set before a race.
There's indicator LEDs on the Dash2 for indicators, oil pressure, rain lights, and screen heat, so I'll know they're on.
Camera switch provides power for my Go-Pro cameras, they go flat if I forget to turn them off and don't re-charge them. (There's no cigarette lighter socket in this car!)
Data logger power is independent of ignition because I want to be able to record during start and cool down.
Logging is indicated on the LCD.
Wiper is indicated by a wiper arm swinging across the windscreen..........
The start engine button lights up red when the ignition is on, it's a bit gimmicky. I could have used a momentary toggle switch and a missile switch cover I suppose. It's worth having this one different to the other switches though.
Wiper and indicator switches are centre off types.
Washer switch is momentary type.
The black buttons control the dashboard display and the red button starts the data logger.
7? MK1 Caddy
12 Amarok
The best part about owning a race car isn't it?
7? MK1 Caddy
12 Amarok
