Page 57 of 94 FirstFirst ... 747555657585967 ... LastLast
Results 561 to 570 of 937
Thread: Another Wreck, another Race Car.....
  1. #561
    Boronia VIC
    Just a few more.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #562
    Jul 2009
    Geelong, Victoria
    awesome thread , great pics, that shot on the jack is amazing - rigid car for sure!
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
  3. #563
    Jun 2007
    Eastern Suburbs Melbourne
    Great work Pete.
    Can't wait till Sunday!
    Give us a hoy if you need a hand!
    i like volkswagens
  4. #564
    Dec 2008
    Bentleigh, Melbourne
    Amazing work Pete!!
    Gotta love a big red 'engine start' button!
  5. #565
    really looking forward to seeing this on Sunday Pete! Looking amazing
  6. #566
    Perth. WA
    Looking great there Pete, cant be far from blast off !!
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  7. #567
    Boronia VIC
    Very close now, it's mainly together.
    Still a few wires to run in and terminate.
    There's still programming and debugging to do on the ECU, data logger and dash yet, that'll take me a little while to nut out and document.
    I need to have the dash talking to the ECU before I start it so I can see oil pressure and temperatures.
    I also need to have the brake pressure sensors reporting to the dash so I can set the initial bias.
    I've filled the brake system with AP PRF 660 fluid and had two small leaks to sort out.
    (I took the cheaper option and used regular Castrol super DOT4 fluid in the clutch system.)
    One leak was a brake light switch which was easily sorted and I've just spotted a weeping union in one of the rear lines, that'll just need nipping up.
    I don't think I'll get the front spoiler done for DOVW at this rate, I'm just running out of time.
    Hanging the doors and guards won't take too long, they've been on and off the car a lot of times now.
    There's a few little touch ups to do to the paint here and there.
    7? MK1 Caddy
    12 Amarok
  8. #568
    Boronia VIC
    This is the layout of the control panel.
    I've avoided indicator lights because I intend to operate this by touch.
    The only buttons I'm likely to need mid-flight are the wipers and kill switch so I put those where I can find them easily.
    Most other controls are set before a race.
    There's indicator LEDs on the Dash2 for indicators, oil pressure, rain lights, and screen heat, so I'll know they're on.
    Camera switch provides power for my Go-Pro cameras, they go flat if I forget to turn them off and don't re-charge them. (There's no cigarette lighter socket in this car!)
    Data logger power is independent of ignition because I want to be able to record during start and cool down.
    Logging is indicated on the LCD.
    Wiper is indicated by a wiper arm swinging across the windscreen..........
    The start engine button lights up red when the ignition is on, it's a bit gimmicky. I could have used a momentary toggle switch and a missile switch cover I suppose. It's worth having this one different to the other switches though.
    Wiper and indicator switches are centre off types.
    Washer switch is momentary type.
    The black buttons control the dashboard display and the red button starts the data logger.
    7? MK1 Caddy
    12 Amarok
  9. #569
    Jun 2007
    The best part about owning a race car isn't it?
    i like volkswagens
  10. #570
    Boronia VIC
    DIY cabin ergonomics?
    7? MK1 Caddy
    12 Amarok
