Page 52 of 94 FirstFirst ... 242505152535462 ... LastLast
Results 511 to 520 of 937
Thread: Another Wreck, another Race Car.....
  1. #511
    Mar 2008
    Rear shot is a win!
    What size tyres? 215/45/15?
  2. #512
    Boronia VIC
    225/45/15
    Sent from my HTC Sensation Z710a using Tapatalk 2
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #513
    Jan 2012
    UK South Wales Europe
    I tried 215/45/15 on our own kamei car this time around on the 9" rear wheel and will definetly go for 225 next time around though the price difference is silly when i looked around.
    It gives a slight stretch and the tyre wall is a bit higher up though we are comparing that to our 8" front wheel with the 205 on.
    yours are a much better contact patch compared to my 215 rear:
    All sizes | Retro Rides Gathering August 2012 Prescott Hill THP_4272 | Flickr - Photo Sharing!
  4. #514
    Boronia VIC
    I chose the 225/45/15 for it's rolling diameter which works out the same as the stock 185/60/14 so I cold keep with the existing gearbox ratios I'm used to.
    I'd baselined to 8" rims due to class restrictions and the issues I've seen with other light weight cars not being able to get sufficient heat into larger rims/tyres.
    7? MK1 Caddy
    12 Amarok
  5. #515
    Boronia VIC
    Headers are back from ceramic coaters and I've started wiring.
    Rear lights, both fuel pumps and both side of the windscreen are wired back to where the switch panel will be.
    7? MK1 Caddy
    12 Amarok
  6. #516
    Jun 2012
    Hackett, ACT
    This car is truly inspirational...
  7. #517
    Boronia VIC
    Slowy moving through the electricals.
    I've chosen LS1 coils to run in a one coil per cylinder configuration.
    The terminals accept stock VW leads.
    Made up a loom to drive the coils.
    7? MK1 Caddy
    12 Amarok
  8. #518
    Boronia VIC
    Extended the wiper loom and finished off the install of the single wiper setup.
    I've got the range of motion and central park position all working properly.
    7? MK1 Caddy
    12 Amarok
  9. #519
    Boronia VIC
    Got the front indicators in and wired up.
    Mounted small white LED lights for use as rain lights in the bumper holes along with the tow hooks.
    I'll get the tow eyes powder coated yellow.
    7? MK1 Caddy
    12 Amarok
  10. #520
    Boronia VIC
    ECU has arrived from the UK.
    Freshly rebuilt gearbox - finally my peloquin is fitted.
    Odyssey battery I picked up at Phillip Island last weekend.
    This will be the control panel, it's currently under construction and will be painted something other than green.
    It's an ammo box from an Army surplus store.
    7? MK1 Caddy
    12 Amarok
