Great work Pete!
Project's slowed a little whilst I accumulate funds for engine components.
Meanwhile I'm trying to knock off all the chores, the little stuff that takes more time than it should.
I lobbed the 16v and a spare box in the bay so I could figure out some stuff.
I decided against the recommended routing of the CAE shifter cables as I've read the less bends the better.
As this isn't a street driven car I can lose the slack in the cabin.
I also did some welding on the exhaust manifold to include the o2 sensor bung. I needed to have it in the car to see where it would fit.
Now the manifold is sorted I can send it out for ceramic coating.
I'll need to fab a heat shield for that steering boot.
Haven't bothered doing much adjustment to the shifter. This was just to locate the firewall holes.
There's a bit of slack in the shifter cables, I think I'll hold them down to the floor with some sort of clamp.
Installed the remote for the kill switch. I had to make a spanner to do the effing nut up under there.
Cable enters the cabin via a grommet directly below the handle.
Haven't figured out a final position for the main kill switch yet.
I'm not planning on using a dizzy so here's the beginnings of a blank off plate.
I made it in 2 pieces because that's the scraps I had lying about.
Not going to buy a billet for a little thing like that.
Geoff Hale donated some stub axle spacers to the cause.
"Some assembly required."
I managed to find an original Rallye Racing decal online from Germany.
Top decal is the original below it is a reproduction I made from it in vinyl.
Now that I've done the artwork I'm going to scale a pair of the to fit the headlights nicely.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Great work Pete!
Love the shifter and pedal set up, looks so cool.
Awsome work.
MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
MK6 GTI: MY13, DSG , very stock
Ducati 749
this is coming along very nicely!!!
Made some parts.
I needed some clamps to hold stuff to the rollcage so I made some from some 16mm aluminum plate.
Here's some pictures in no particular order.
Local wildlife helping out again.
Bit of cleaning up to do at this stage, you'll see what they're for in a post or two.
7? MK1 Caddy
12 Amarok
Got around to finishing off attaching the throttle throttle cables to the pedal box.
This is a delicate little job, that bit is only 3mm diameter.
Put a flat on the pedal shaft for the grub screw to lock onto.
This is the part that attaches the cable to the pedal. I really hate unreliable throttle linkages, this is probably over engineered.
Cables coming into the engine bay.
And the pedal box back in the footwell.
7? MK1 Caddy
12 Amarok
Good stuff, mate. Looking very nice.
I see you bought some machines, Pete. Nice work. Had the mill long?
Another quick job, I mounted up the rear view mirror.
This came with rollbar mounting clamps but I couldn't use them as there's not enough room between the bar and the windscreen frame to use them.
So rather than use the included clamps I made up a couple of new ones that bolt into a couple of nutserts I put into the bodywork.
Here's the bracket I knocked up from some 5mm aluminium angle.
Brackets installed.
Super wide angle 17" mirror from Joes Racing.
The view is crazy wide you can see out of the doors!
7? MK1 Caddy
12 Amarok
7? MK1 Caddy
12 Amarok
