Page 44 of 94 FirstFirst ... 34424344454654 ... LastLast
Results 431 to 440 of 937
Thread: Another Wreck, another Race Car.....
  1. #431
    Boronia VIC
    Small things amuse small minds but do also require a stupid amount of time to research and procure.
    These are bits for the brake system.
    4 way M10 brake unions
    Stop light switch (I'm going to put one in both front and rear circuits)
    BMW Brake Pressure sender (So I can log brake pressures, again, front and rear.
    and all the little bits that make up the connector for the pressure sensors.
    For those of you interested in logging, the BMW sensors are a lot cheaper than the motorsport equivalents, are M10 and will read to 250Bar. Their curve is linear and the data sheet is readily available to program your logger.
    Bosch part number is 0 265 005 303
    BMW part number is 34 51 1 165 467
    Part numbers for the connectors can be found in the data sheet. http://apps.bosch.com.au/motorsport/...ghpressure.pdf
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #432
    Dec 2008
    sydney
    Awsome build mate, that's one stunning vehicle
    quality of work is outstanding
    MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
    MK6 GTI: MY13, DSG , very stock
    Ducati 749
  3. #433
    Perth. WA
    Very techo Pete, logging brake pressure in each circuit. Will be some good info coming out of this me thinks.
    Any reason why you went with a hyd brake light switch and not a mechanical version ??
    All coming together nicely anyway.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  4. #434
    Jun 2006
    Orange NSW
    Individual brake pressure.. That's pretty tricky. When I was crewing on a Fujitsu car a few years ago, even that only had front/rear.
  5. #435
    Boronia VIC
    Just front/rear Chris, I got a couple of spare connectors.
    I went with the hydraulic switches because I couldn't figure out an elegant way to mount a mechanical one on the pedal box. All the likely locations were in places I might step on.
    Sent from my HTC Sensation Z710a using Tapatalk 2
    7? MK1 Caddy
    12 Amarok
  6. #436
    Dec 2009
    Fitzroy, VIC
    Quote Originally Posted by VR6man View Post
    I'll second that. Best bit about reading your threads/posts Pete is the level of detail combined with your expertise makes it a quality learning experience every time!
    Expressed as an equation for awesomeness: Detailed Posts X Expertise = Kick Ass Thread
    PS - Good idea heading to Purple Pig, got shafted a few years back buying an OEM tank-to-filler pipe.
  7. #437
    Jan 2012
    UK South Wales Europe
    Hi Peter
    Looking good.
    Markus Seidl has now finished the rally car, few pics & link for you:
    clubgti.com - View Single Post - Markus Seidl - Seidl Racing - race cars. UPDATE Kamei Rally Car finished!!!!!
    His other cars:
    clubgti.com - Markus Seidl - Seidl Racing - race cars.
  8. #438
    Boronia VIC
    I've made all the brake hard lines and roughed them in. There's still the clutch lines to do but I don't know where I'm going to go through the firewall yet.
    7? MK1 Caddy
    12 Amarok
  9. #439
    Jun 2006
    Orange NSW
    Nice...
  10. #440
    Boronia VIC
    Pulled the beam and tank out again today to change the breather hose now that I've decided on a roll over valve setup.
    With that done it was time to install the filler.
    I knocked the bearings into the rear discs and greased them up today so they got fitted up.
    Waiting on bits in the mail to finish off the rear brakes.
    7? MK1 Caddy
    12 Amarok
