this car is looking too good for racing!! i love your attention to detail on everything.
again, cant wait to see this tearing it up!!
Spent most of yesterday running around trying to find fasteners and brake fittings.
Stripped down 3 separate steering columns to find good bearings which I cleaned up and re greased.
I sandblasted the rack and column before painting them black.
The column got a couple of extra braces welded to it as stock ones tend to fail.
The steering shaft boot is original from the car, oddly the best one second hand I've ever come across.
Sorted out the lines to the reservoirs. Probably overkill. I'll make a stay to make sure the clutch line doesn't get near the column or perhaps a right angle elbow.
I cut the steering lock off the column. Some racing classes demand that the steering lock is removed.
For the moment the column is in the stock location, once the seat is in I might lower it a few inches
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Great updates as usual.
Peter with the steering column brackets people tend to also run a brace across from one side to the other to remove a bit more flex and increase the life of the brackets.
http://img.photobucket.com/albums/v9.../DCP_6188s.jpg
7? MK1 Caddy
12 Amarok
Ah i mean the brackets in the engine bay sorry, pic attached to my last post as example.
I was wondering if that's what you meant.
The early cars like mine don't really suffer from that problem as the rack bolts up solid at both ends. The supporting brackets are different and I've seam welded them in any case.
7? MK1 Caddy
12 Amarok
Yes i thought they looked a bit different, only the very early ones were solid![]()
was great to see the car today peter, really looks great!!!
again, thanks for the parts![]()
Got a tank in over the weekend, it's a diesel one I've cleaned up.
Need to source a suitable roll over valve for the breather.
Suitable fuel hose for the tank to filler connection is 38mm if anyone needs to know. I got this piece from Purple Pig. (Yes that's a real business! Purple Pig - Industrial hoses, fittings and rubber products.)
7? MK1 Caddy
12 Amarok
