Page 30 of 94 FirstFirst ... 2028293031324080 ... LastLast
Results 291 to 300 of 937
Thread: Another Wreck, another Race Car.....
  1. #291
    Mar 2009
    this should make a nice daily! ahah ... as above 'speechless', looking forward to more progress! will be watching space....
    78 2-door 1.8 KR 16v - twin dellorto's
  2. #292
    Boronia VIC
    Got stuck into the seat mounting today.
    The design is based on information I got from the cage builder, Brown Davis.
    It's a simple H pattern made from 25mm x 25mm RHS steel, 2mm thick and 350mpa.
    To retain tube strength threded inserts are welded into the tubes to take the seat brackets.
    1.6mm thick steel reinforcing plates are required to spread the load over the thin panel steel.
    The floor isn't very strong and not a great place to mount stuff off, so 2 bars span the floor half attaching to the tunnel in the centre and the sill on the outer.
    2 members run front to back between the spanning members, these should be a long as possible for the most leverage on the seat.
    I'm going to use the seat I already have from my other car, but it's base mounting so I had to get side mounting adaptors as well as the side mounts to make it all work.
    Had to throw a couple of interior items in to work on positioning everything in the cabin.
    Crash hat was also used to check headroom.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #293
    Boronia VIC
    I had to buy a whole sheet of 1.6mm, I'll find a use for it eventually.
    Plasma cutter made short work of cutting out the plates.
    Next was shaping the plates and laying out the tubes.
    7? MK1 Caddy
    12 Amarok
  4. #294
    Boronia VIC
    Profiling the ends of the tube to match the contour of the body was a complete pain in the rear.
    Bending the plates was easier.
    just a quick check while it's just tacked together.
    "H" fully welded and the tacked to plates.
    "H" and plates getting fully welded to each other.
    7? MK1 Caddy
    12 Amarok
  5. #295
    Boronia VIC
    I made the threaded inserts from 20mm round bar.
    Step 1
    Steps 2 and 3
    Only drilled at this stage I tapped them after welding.
    7? MK1 Caddy
    12 Amarok
  6. #296
    Boronia VIC
    Cleaned up for welding
    Undercoated frame before welding it in.
    Guess I'm stuck with it now!
    Side brackets trial fitted.
    And seat bolted in.
    7? MK1 Caddy
    12 Amarok
  7. #297
    Boronia VIC
    All of that took the entire day.
    Seat mounting is not one of my favourite jobs.
    7? MK1 Caddy
    12 Amarok
  8. #298
    Jun 2006
    Orange NSW
    Nice work, Pete.
    I don't enjoy mounting seats, either. My Uncle has also been not enjoying making seat mounts in his Porsche 914/6 GT.. It's just a PITA job..
  9. #299
    Mar 2009
    nicely done pete...i also hate seat mounting...time consuming and fiddly.
  10. #300
    Fantastic!! As always great detail in your posts.
    76 Mk1 Golf 2dr 20VT BERG (project..)
    01 WRX
    89 SIR CRX
