Page 18 of 94 FirstFirst ... 816171819202868 ... LastLast
Results 171 to 180 of 937
Thread: Another Wreck, another Race Car.....
  1. #171
    Jun 2006
    Orange NSW
    Very neat cage, Pete. I like it.
    Like anything, there's more to it than is visually recognisable.
  2. #172
    nice Pete! Good to see it progressing so fast! Next the Engine?
  3. #173
    Boronia VIC
    Quote Originally Posted by GoLfMan View Post
    Engine is last.
    Lots of bodywork first then suspension and brakes.
    Much wiring too.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  4. #174
    Sydney NSW
    Jun 2006
    Orange NSW
    Quote Originally Posted by Check'rd Lad View Post
    There's nothing like Fresh MK1
    That's taking over the bukkake sig.. spelling corrected.
  6. #176
    Boronia VIC
    OK. Been quiet for the last week, painted the bedroom and installed some stainless steel balustrading.
    Back to the cars now
    The golf is back up on the rotisserie now and the suspension is back out.
    Just getting back into some rust repairs now.
    First up is a tricky bit, firewall.
    There's actually 3 panels that meet at the seam across the firewall.
    The lowest of the panels is the main bulkhead which has an upturned flange on which the next two panels sit. The bulkhead panel is quite thick being a structural member of the car.
    This is a panel I'm fabricating to replace the firewall above the seam. I made the bends with a cheap bender ($60) from the local tool place.
    This is the section that the piece above is to replace.
    The wheel well came out yesterday. More on that later.
    Spot welds cleaned up
    New piece held in temporarily for rough trimming.
    From the inside.
    At this point I've got to make and install the lower repair piece before I can do any more with the upper section.
    Before it gets cut out a new piece needs to be shaped. Here's piece 2 with another flange bent onto it.
    7? MK1 Caddy
    12 Amarok
  7. #177
    Boronia VIC
    Marking up.
    Rough trim of new piece.
    Clamp in new piece.
    Beat the snot out of it with assorted hammers.
    Here's the two pieces upper and lower so you can see them taking shape.
    Marked for cut out.
    Remove lower section
    Trial fit looks good enough to proceed.
    7? MK1 Caddy
    12 Amarok
  8. #178
    Boronia VIC
    From the engine bay side
    Easier to punch holes than try and drill sheet metal.
    Lower repair panel in place
    Clamped.
    Spotted back to the flange.
    Tacked,
    and welded!
    Bit of a tidy up with the grinder.
    7? MK1 Caddy
    12 Amarok
  9. #179
    Boronia VIC
    Tomorrow I'll finish shaping and attach the upper piece.
    7? MK1 Caddy
    12 Amarok
  10. #180
    Jun 2007
    Eastern Suburbs Melbourne
    Looking good Pete!
    i like volkswagens
