nice Pete! Good to see it progressing so fast! Next the Engine?
Very neat cage, Pete. I like it.
Like anything, there's more to it than is visually recognisable.![]()
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Nice work with the cage! theirs nothing like Fresh MK1![]()
OK. Been quiet for the last week, painted the bedroom and installed some stainless steel balustrading.
Back to the cars now
The golf is back up on the rotisserie now and the suspension is back out.
Just getting back into some rust repairs now.
First up is a tricky bit, firewall.
There's actually 3 panels that meet at the seam across the firewall.
The lowest of the panels is the main bulkhead which has an upturned flange on which the next two panels sit. The bulkhead panel is quite thick being a structural member of the car.
This is a panel I'm fabricating to replace the firewall above the seam. I made the bends with a cheap bender ($60) from the local tool place.
This is the section that the piece above is to replace.
The wheel well came out yesterday. More on that later.
Spot welds cleaned up
New piece held in temporarily for rough trimming.
From the inside.
At this point I've got to make and install the lower repair piece before I can do any more with the upper section.
Before it gets cut out a new piece needs to be shaped. Here's piece 2 with another flange bent onto it.
7? MK1 Caddy
12 Amarok
Marking up.
Rough trim of new piece.
Clamp in new piece.
Beat the snot out of it with assorted hammers.
Here's the two pieces upper and lower so you can see them taking shape.
Marked for cut out.
Remove lower section
Trial fit looks good enough to proceed.
7? MK1 Caddy
12 Amarok
From the engine bay side
Easier to punch holes than try and drill sheet metal.
Lower repair panel in place
Clamped.
Spotted back to the flange.
Tacked,
and welded!
Bit of a tidy up with the grinder.
7? MK1 Caddy
12 Amarok
Tomorrow I'll finish shaping and attach the upper piece.
7? MK1 Caddy
12 Amarok
