Press or hoist ?????
Teaser!
I knew I should have dropped by today!![]()
Lots of MK 1 Scirocco's...
Cheers,
Grant...
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Chose to not make your own? That ought to make things easier.![]()
7? MK1 Caddy
12 Amarok
rotissary!
yay, this means some major progress can get under way!
Here's some pics of the "AutoTwirler" as the assembly instructions call it.
I was hoping to get the car up on it this weekend, but it was delivered missing one wheel (it's on it's way now) and the cross pieces are a little short to pick up the bumper locations.
I'll make new cross beams, it's just a 1.2m length of 3mm 50x50 RHS with some holes drilled in it.
I drilled the arms for the MK1 bumper iron mounts and welded nuts to the back of the tube so it just bolts up like a bumper.
Bumpers usually mount with M8 bolts, I've upped it to 12mm for this application.
7? MK1 Caddy
12 Amarok
so does it jack it up and flip it?
is the other side identical as well?
Some progress.
After way too long we extracted the blue golf from the pile of rubble that had grown around it since we had it out last.
It's over on the other side of my garage now so I can get some work done on it.
Today -
- Removed wiring from engine bay
- Removed rain tray
- Removed battery tray
- Removed brake booster and linkages.
- Removed tar matting from rain tray area.
- Removed wiper mechanism.
- Removed windscreen
- Removed front guards
- Pulled some other stuff out too....
All looking pretty good so far, only a few minor rust spots under the matel I removed and a very good windscreen area.
7? MK1 Caddy
12 Amarok
7? MK1 Caddy
12 Amarok
