Starting to collect stuff for the eventual e85 conversion. Probably wont finish it off until the end of the season.
Here's what I'm up to.
This is an e85 tester. It tells you the % of ethanol in the fuel. It appears my local United is closer to being e90.
I'm wiring a flex fuel sensor into the data logger. This measures the ethanol % and fuel temperature. This will let me log the fuel quality so I can review it should I suspect a fuel issue. I'll plumb it into the return line to the tank. That blue hose will be cut and terminated to run through it.
This is an e85 proof fuel level sensor. It works on capacitance and has no moving parts. This will allow me to run foam in the tank. I had this custom made in China for about $150. A local sensor company quoted me $1600 for the same thing.
I mounted it in the top of an old sensor which I'd gutted. The thread is M20x1.5 so I was able to modify a CV nut and braze it to the old top for the new sensor to screw into.
This will be wired into the logger too, it's main function is simply a fuel gauge so I know if I need top up between rounds.
You use up to 30% more fuel volume with e85 so I'll be keeping a close eye on consumption.
The reason I never did e85 from the beginning was the fuel tank. e85 absorbs moisture from the air and can become corrosive to steel and aluminum parts. As my original tank already has a few rust spots it was all bit bit hard at the time.
This is a brand new tank from the UK. It has some differences to the OEM tanks that will make this thing possible.
In order to make the tank proof against e85 I will line it with a POR-15 product designed to seal fuel tanks.
POR-15 Fuel Tank Sealer
There is no trap door on the filler and there's not the plastic surge tank/filter holder that the OEM tank has. Both of those would have made using the sealer very difficult.
Because this is a brand new tank there's no safety issues with brazing AN fittings onto the pipes for more secure hose work.
I'm doing some very amateur science here and chucked a bunch of different metals and hoses in some e85 to see what happens. I've got one bucket where they're all submerged and another where they're partially submerged. Just curious to see if the horror stories are true.
I also have to swap out my Integrated Engineering surge tank for the version with the anodised insides and run new anodised hard line front to back.
If I can figure out all of that then it'll be off to the dyno for a retune.
