Page 90 of 94 FirstFirst ... 40808889909192 ... LastLast
Results 891 to 900 of 937
Thread: Another Wreck, another Race Car.....
  1. #891
    Nov 2014
    Trailing throttle at apex
    OK now Ihave seen the sequence for the Evo it was his fault, from the first still it looked more 50/50 but he didn't lock them up and let the car finish its business - when you have lost it it is lost, just bail out - the car will travel in a straight line once you lock it all up, that Newton bloke was on to something
  2. #892
    Boronia VIC
    Starting to collect stuff for the eventual e85 conversion. Probably wont finish it off until the end of the season.
    Here's what I'm up to.
    This is an e85 tester. It tells you the % of ethanol in the fuel. It appears my local United is closer to being e90.
    I'm wiring a flex fuel sensor into the data logger. This measures the ethanol % and fuel temperature. This will let me log the fuel quality so I can review it should I suspect a fuel issue. I'll plumb it into the return line to the tank. That blue hose will be cut and terminated to run through it.
    This is an e85 proof fuel level sensor. It works on capacitance and has no moving parts. This will allow me to run foam in the tank. I had this custom made in China for about $150. A local sensor company quoted me $1600 for the same thing.
    I mounted it in the top of an old sensor which I'd gutted. The thread is M20x1.5 so I was able to modify a CV nut and braze it to the old top for the new sensor to screw into.
    This will be wired into the logger too, it's main function is simply a fuel gauge so I know if I need top up between rounds.
    You use up to 30% more fuel volume with e85 so I'll be keeping a close eye on consumption.
    The reason I never did e85 from the beginning was the fuel tank. e85 absorbs moisture from the air and can become corrosive to steel and aluminum parts. As my original tank already has a few rust spots it was all bit bit hard at the time.
    This is a brand new tank from the UK. It has some differences to the OEM tanks that will make this thing possible.
    In order to make the tank proof against e85 I will line it with a POR-15 product designed to seal fuel tanks.
    POR-15 Fuel Tank Sealer
    There is no trap door on the filler and there's not the plastic surge tank/filter holder that the OEM tank has. Both of those would have made using the sealer very difficult.
    Because this is a brand new tank there's no safety issues with brazing AN fittings onto the pipes for more secure hose work.
    I'm doing some very amateur science here and chucked a bunch of different metals and hoses in some e85 to see what happens. I've got one bucket where they're all submerged and another where they're partially submerged. Just curious to see if the horror stories are true.
    I also have to swap out my Integrated Engineering surge tank for the version with the anodised insides and run new anodised hard line front to back.
    If I can figure out all of that then it'll be off to the dyno for a retune.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #893
    What's the benefit in running e85? So far all I'm hearing is negatives - use up to 30% more, corrosive, lot of work needed to convert.
  4. #894
    Boronia VIC
    More power.
    Cheaper fuel.
    Cooler running engine.
    20 litres of 105 race fuel costs me $85 and a 3 hour round trip to purchase it.
    20 litres of 107 e85 costs $26.40 and a 10 minute round trip to a servo just down the road.
    7? MK1 Caddy
    12 Amarok
  5. #895
    brisbane
    this is an engineering masterpiece, well done. i love the quality of your work...
  6. #896
    Nov 2014
    I have one of those simple eBay testers, and ave also found around 90% is normal I know people who use the flex fuel sensor, but I don't have the capacity with the Autronic
    Apparently United is pretty consistent , Caltex is a lot more variable (E70 to E90)
    My experience is 22% at WOT, less as an average
    Your "bucket of Fuel" is exactly what I did!
  7. #897
    Boronia VIC
    Good to know that United tends to be consistent.
    From memory I think Caltex makes their ethanol from waste and United is from wheat/sugarcane?
    22% is OK for the racing I do. I tend to use fuel as ballast if I've got traction issues and I'm still running a full sized 40L tank.
    7? MK1 Caddy
    12 Amarok
  8. #898
    Nov 2014
    United brought the CSR/Dalby refinery, so control their own supply chain
    Caltex go to a variety of sources (including United) and blend form there. If they have poor supply (or it is dear relative to spirit) the percentage changes
  9. #899
    Boronia VIC
    Dramas yesterday out at Sandown.
    Was going pretty well cutting 1:29 laps in the second round when I snapped the timing chain.
    Bottom end should be OK. Head is off to see if it can be salvaged and what parts it's going to take.
    Probably need to have all valves and buckets replaced as well as several of the guides as a bare minimum.
    Should be enough time to get it fixed before the next round.
    7? MK1 Caddy
    12 Amarok
  10. #900
    Boronia VIC
    The bolts on the adjustable cam gear sheared off and did a lot of damage around the bearing saddle nearest the dizzy.
    Broken chain. Might have been the cam pulley bolts that let go first. Hard to tell which was the cause.
    This was only the second outing on this pulley. It's stuffed now.
    I don't think this is what's meant by valve overlap.
    Inlet buckets got smashed up.
    7? MK1 Caddy
    12 Amarok
