Page 82 of 94 FirstFirst ... 3272808182838492 ... LastLast
Results 811 to 820 of 937
Thread: Another Wreck, another Race Car.....
  1. #811
    Boronia VIC
    Lap times as always. The fastest time for an under 2000cc Sports sedan at PI is 1:42 I'd like to see how close I can get to that.
    I think I can get below 1:50 this season with some more practice.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #812
    Jan 2012
    St Albans, Victoria
    Er.....Pete.......I think I can see where you can improve the power to weight ratio.
    Paul
    That's a little harsh?
  3. #813
    Boronia VIC
    Remember that gearbox I blew up at the end of last season? I pulled it apart today to find out what it was that went bang.
    I was in second gear accelerating out of a corner and second gear clearly lost the will to live.
    Rest of the gearbox looks OK. I just need a close ratio input shaft and a new second gear to put it all back together.
    7? MK1 Caddy
    12 Amarok
  4. #814
    Dec 2012
    Sutherland Shire, Sydney
    Ripper!
  5. #815
    Nov 2013
    GoldenGrove SA
    Given the strength of VW manual transmissions I would think this is not a common parts failure, i have seen first gear cogs stripped because of enthusiastic launches but second gear cogs, could there have been an issue with the clutch engagement that contributed or marginal input shalf alignment to second gear cog?
    Just a thought please continue.
  6. #816
    Impressive.
    Just how much power and torque is this engine making?
  7. #817
    Boronia VIC
    These 020 gear boxes aren't renowned for their strength although it is usually the diff rivets that are the cause of that reputation.
    All these boxes are getting pretty old now could be an age related fatigue thing contributing too I guess.
    Box has about 1000km of race use since rebuild so all the bearings should be OK and looked alright when I dismantled it.
    Redline synthetic oil too.
    Clutch was fully engaged when it blew.
    I down shifted to second on the entry to Honda and was feeding the power back on through the corner. At exit I went full throttle and the gear let loose.
    I captured it on video too!
    I think the difference this time was traction. This is the first occasion I'd gotten my Hoosier slicks up to temp. Normally I'd be spinning the wheels out of this corner, This time it hooked up and blew the gear.
    7? MK1 Caddy
    12 Amarok
  8. #818
    Boronia VIC
    Impressive.
    I'm not sure. When I had it tuned at MPC there were issues with getting their dyno setup to work with my little car, I think the plot showed only about 118kW which doesn't seem right. It's built to be in the 250-300 HP range.
    The main thing at that point was to set the motor up and do some basic running in. We weren't doing any real power runs as the motor hadn't been run in at that stage.
    I've got some clutch adjustment to do and then the plan is to get back on the dyno for a retune. I should find out then what the numbers look like.
    7? MK1 Caddy
    12 Amarok
  9. #819
    Jun 2007
    Eastern Suburbs Melbourne
    wow, that's well and truly seen better days!
    I spose with the slicks on, you found the weakest link!
    i like volkswagens
  10. #820
    Boronia VIC
    Crappy day of racing at Sandown today.
    Cam Angle sensor issues kept shutting me down.
    My best and only timed lap was 1:32
    However I was still faster than the only other competitor in my class and about 28th overall in a field of 81.
    7? MK1 Caddy
    12 Amarok
