Results 1 to 10 of 937
Thread: Another Wreck, another Race Car.....
    Oakleigh VIC
    The rear mount was out of alignment too so I modified it to take a rear suspension bush.
    The urethane block style rear mounts are notorious for breaking in half I'm hoping this is a more reliable option.
    I had the square block style on this bracket and it had bent it slightly around the bolt hole so I wasn't worried about modifying it.
    This is how it came together.
    The 02J case actually fits better than the 020 even with the 6th gear extension housing.
    Just had to tweak the brake line a little.
    The 020 release bearing cover use to come out into the wheel arch through that semi-circular cut out.
    Had to turn up an alignment tool.
    I removed an un-used lug from the front of the starter motor housing. It would have fouled the radiator so it had to go.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Dec 2007
    Perth, WA. *YAWN*...
    Sexy!!!
