Page 78 of 94 FirstFirst ... 2868767778798088 ... LastLast
Results 771 to 780 of 937
Thread: Another Wreck, another Race Car.....
  1. #771
    Boronia VIC
    Quick clip of the CV failing.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #772
    bugger!
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
  3. #773
    Jun 2007
    Eastern Suburbs Melbourne
    ouch!
    10chara
    i like volkswagens
  4. #774
    Jan 2006
    Crunch. Did you see if the LSD would still drive the good trans-axle or just go open diff? Would have been a good opportunity to test it
  5. #775
    Perth. WA
    any damage under neath other than a dead CV ??
    And something completely different.... What oil brand, type and grade you running in the Wavetrac box Pete, have you changed it yet
    ( looked ok, contaminated etc )
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  6. #776
    Boronia VIC
    Car still drives, just sounds really crunchy!
    No other damage so far.. I pulled the LHS axle out yesterday but it looks OK. Inner CV is fine, I ran out of time to dismantle outer but it looks OK too.
    Boots aren't twisted up at all.
    I'll pull the RH one one next.
    This problem might be inside the box yet.
    If the CVs all look OK, I'll put some old axles in and see if it's the gear box.
    I was really expecting to find shrapnel in the outer L/H CV.
    Gear box oil in this one is Penrite , pretty sure it's 75W90 fully synthetic, I'll have to check the bottle. Haven't dropped the oil yet to look for metal chunks.
    The other box had Redline in it and 3rd synchro was problematic from day 1 post reco.
    7? MK1 Caddy
    12 Amarok
  7. #777
    Jun 2011
    Unfortunate about that mishap.
    I had this happen one time, the driveshaft bolts snapped and the shaft was no longer connected to the gearbox. Shaft spun and was hitting on frame, ground engine making a similar noise to what's in the video.
    I'm sure if this happened to you though you would have seen this problem straight away
    "I only post on Facebook if I know i am going to get likes" - M
  8. #778
    Perth. WA
    Thanks for that Pete, hope nothing to expensive has detonated
    Cheers,
    Grant...
  9. #779
    Jan 2012
    UK South Wales Europe
    Hi Peter how are things with you?
    Did Uwe at Kamei get in contact after i reminded him again and did you get anything in the post from him this year?
    Merry Christmas
  10. #780
    Boronia VIC
    Nothing in the post so far Mike.
    Car's going great, keeps getting faster as I learn how to drive it.
    My new gearbox is about to arrive from Eurospec in the next couple of days. That should speed things up a lot.
    I keep seeing your car pop up in the magazines. Hope it's all going well.
    Merry Christmas to you too!
    7? MK1 Caddy
    12 Amarok
