Congrats on the award yesterday Pete.
Car sounded great!![]()
Pics from DOVW
Next event is the Geelong speeds trials, I'm running on the Saturday.
Geelong Revival
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Thanks Jarred,
I got a dirty look from Lloyd for skidding to a stop.
But in my defense - button clutch, 200+ horsepower, no 1st gear, wet grass, on a hill and slick tyres I'm amazed I got it too the presenting area at all!
The plugs were a bit fouled from idling about too so I was having to heel and toe it to keep it idling nice.
The rev as I took off was a little uncalled for but I only blipped it to 5000rpm![]()
7? MK1 Caddy
12 Amarok
A very nice looking engine bay, along with the rest of the car too. Function is the best form. Congratulations.
Tell the truth. You're a hoon and proud of it.
I'm nearly 60 and I'm still spinning my Golf on tight roundabouts in the wet because I'm showing off how well my car corners. Trust me, even with grey hair and a white beard I still get people shaking their heads when they have to drive around me because my car is facing the wrong way.
Yeah, I know, I'll grow up one day.
Love that engine bay, that's how all modified MK1's should look!
Paul
Just read this from start to finish (over 2 days!) and a very impressive build
Well I am pretty sure that will be re-set this weekend as the Beninca Alfa will be at Island Magic. I am not racing but I will be helping a mate
Subscribed to your youTube channel, lots of good stuff there, like me, I just post everything up, ,all part of the fun. You are leaving a lot on the table (especially T12) I agree with you, bit of practice and sub 1.50 is definitely there, but that will take a big commitment. I would suggest you soften the rear at this stage, you have it set up about right, looks like stiffer in the rear than the front, but at this stage softer at the back will make it easier to drive, you will go faster
Did you ever get it back on the dyno? 'Cause it is a hell of a lot more than 118wkW! Pulls nicely, I would guess close to 150 on MPC
I've just finished another dyno tune and there's lots to update. New figure is 135.8kW at the wheels, 4th gear, 240km/h. Still more in it yet. Maybe E85 down the track.
I learned that CV boots don't survive 240km/h and close proximity to header pipes.
I'll add more to the story after the Geelong event.
7? MK1 Caddy
12 Amarok
Good call on the rear end by the way, I've been running with the rear sway disconnected to get more rear grip, particularly in the wet.
7? MK1 Caddy
12 Amarok
Cheers, been around a bit
What compression are you running?
what sort of revs are the peak power?
I have backed to back E85 and it has a lower calorific value, but a great octane (114) so you may not find a great advantage in NA, if your tune is limited by detonation then fine, but other wise the extra volume 22-25% of fuel hurts because it displaces air(!) ie the power producing stuff, and more weight to carry around...
My old turbo Laser TX3 loved it, the Telstar doesn't , less than 1kW extra peak powerbut less torque in the mid range
13.5:1 compression currently running PowerPlus 105 Octane
Here's the latest plot, ignore the oscillations and the spike just after 4500 there's an issue with the rollers on this dyno at the moment.
7? MK1 Caddy
12 Amarok
