CAMS came out and sealed the motor last night.
Sump and head are wired on and tagged.
Now to press on with the rest of the assembly.
you've definately been busy, great work Pete!
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
great news!!!
quick question:
what milling machine do you have??
looks like the perfect size for home use.
another step done Peter. Such a bummer I can't make it to DOVW this year to see this beauty...
It's an Hafco HM-46 M123 | HM-46 Mill Drill - Geared & Tilting Head | machineryhouse.com.au
There's cheaper and dearer options depending on the column style and accessories.
Mill Drill Milling Machines | machineryhouse.com.au
I've fitted a power feed on the x axis. For Christmas I might buy myself a DRO to go it.
It's a good size for working on car stuff, It's a Mill/Drill so it's pretty versatile.
I just made a new drawbar for it so I use a wider range of tooling.
They come with a 1/2" whitworth drawbar whereas all the cheap tools on ebay are M12..
Of course The minute I get around to making a metric drawbar I discover that you can buy them on ebay for $19![]()
7? MK1 Caddy
12 Amarok
love your work as usual Pete!
Very, very busy trying to put this together for DOVW.
I've been doing 3-4 hours a night on the wiring alone.
Here's a bunch of pictures to tide you over 'till Sunday.
Chain reinforced, wire reinforced, regular old style and new style exhaust hangers.
Made a pipe to connect the headers to the rear system. Got it ceramic coated.
Put some heat sheild up here to try and keep some of the heat out of the cabin.
I don't like saggy exhausts. This bend always seems to drop as it's unsupported. I used a universal hanger to improve on the stock lack of support.
Hover Golf
7? MK1 Caddy
12 Amarok
Started buying fluids.
The box oil is in.
Brakes and clutch are primed.
Still a few hoses to tighten and sensors to fit before the engine oil goes in.
I'm getting very weary of connectors.
Weird colour this stuff.
Visiting King Parrot.
Heat shield for headers.
Bosch motorsport lambda sensor.
New pipe mated up.
resonator and mid hanger.
Added heat shield tube over handbrake cable just in case.
7? MK1 Caddy
12 Amarok
Last few pics for tonight.
Car is pretty rigid now. jacking one side lifts the other.
7? MK1 Caddy
12 Amarok
