Page 55 of 94 FirstFirst ... 545535455565765 ... LastLast
Results 541 to 550 of 937
Thread: Another Wreck, another Race Car.....
  1. #541
    vic
    Good news Peter, great work so far!
  2. #542
    Jun 2007
    Eastern Suburbs Melbourne
    woohoo, congrats Pete, great news.
    i like volkswagens
  3. #543
    Boronia VIC
    Spent a few nights this week sorting out cam angle sensor.
    Had to make a hybrid of a new KR hall effect sensor and an ABF housing so I could use the single window rotating vane.
    Don't need to distribute spark so I made a cap.
    I need a cam angle sensor to run coil per cylinder and sequential injection.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  4. #544
    Boronia VIC
    Started bolting down the electrical stuff.
    Here's the switch box a little closer and a little less green.
    Battery is bolted down in that position now.
    Made a cage for the ECU and bolted it in.
    Found somewhere to mount the logger.
    Interior taking shape. I had to put the seat back in so I could position the switches.
    Routed and secured the hoses in the engine bay.
    7? MK1 Caddy
    12 Amarok
  5. #545
    Boronia VIC
    Installed the fire system.
    One nozzle in the engine bay.
    Battery cutoff on the left and fire extinguisher on the right.
    There's still decals to put on to mark the functions.
    Second nozzle in the cabin pointed at the driver's midriff.
    Still have to clip down some of the cables and hoses.
    7? MK1 Caddy
    12 Amarok
  6. #546
    Boronia VIC
    Hi torque starter motor.
    These are a geared unit and look to be an adaption of the 16v Toyota starters.
    As supplied it was a little too close to the radiator so I removed the adapter plate and reworked it to rotate the starter into a new position.
    7? MK1 Caddy
    12 Amarok
  7. #547
    Boronia VIC
    Finalised the mounting and linkage for the clutch slave cylinder. Just need to sort out a custom hose for it next Saturday.
    7? MK1 Caddy
    12 Amarok
  8. #548
    Boronia VIC
    Roll cage padding can go in now.
    This is the new spec SFI style padding, it's really dense and is easier to work with.
    7? MK1 Caddy
    12 Amarok
  9. #549
    Boronia VIC
    Key chain quick release for the isolation switch so I can remove it from the car when it's not in use.
    7? MK1 Caddy
    12 Amarok
  10. #550
    Dec 2008
    Bentleigh, Melbourne
    FRICKEN HELL, all those little bits are AWESOME!!!!!!!!!!!!!
    well done pete, can't wait to see it at DOVW
