Page 54 of 94 FirstFirst ... 444525354555664 ... LastLast
Results 531 to 540 of 937
Thread: Another Wreck, another Race Car.....
  1. #531
    Jun 2007
    Eastern Suburbs Melbourne
    that' radiator is mighty thick!
    (it also gives away a few clues about the engine )
    i like volkswagens
  2. #532
    Oakleigh VIC
    Made up the lower brace and welded in the mounts in for the upper brace.
    This is a pretty common bark yard design.
    Wire edged a couple of places I'd had to trim too.
    Lower brace painted up.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #533
    Oakleigh VIC
    Got the gearbox ready, It had 100mm output flanges on it so I swapped them over for 90mm ones off another box.
    The 100mm flanges took a lot to get off, had to use a set of 20 tonne pullers.
    Tow hooks came back form powder coating and got installed.
    Made up brackets and mounted the expansion tank.
    Engine bay is starting to look pretty busy now.
    Those BFI engine mounts are a joke. They seem to be made from reasonable materials but the dimensions are all wrong. The bolt hole was too small for the bolt to pass through and the whole thing is too wide.
    The drivers side one is notched to clear a bolt but the notch is in the wrong place.
    Don't buy them unless you've got access to a lathe and linisher to fix them.
    7? MK1 Caddy
    12 Amarok
  4. #534
    Jan 2012
    St Albans, Victoria
    Nice one Pete, keep up the good work.
  5. #535
    Jun 2007
    Nice one Pete.
    I recall Tim Bailey having similar troubles with the BFI inserts
    i like volkswagens
  6. #536
    Oakleigh VIC
    Same ones, I bought these off Tim
    7? MK1 Caddy
    12 Amarok
  7. #537
    Jul 2009
    Geelong, Victoria
    looking good Pete. Lots of nice attention to detail, but kept functional.
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
  8. #538
    sydney
    I've got nothing but good things to say about the BFI mounts I have fitted a treat.
    Looking great Pete.
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
  9. #539
    Oakleigh VIC
    Just had the CAMS scrutineer out to check things over and it's all smiles.
    One minor technicality to do with not running bumpers, but should be able to get an exemption as its a replica, he didn't seem to think it was much of an issue.
    Certainly all the safety stuff is on track to pass without issue.
    Just need to put it all together to get the logboook.
    It will be log booked as a sports sedan which may be a first for a MK1 Golf. Certainly to current regs at least.
    7? MK1 Caddy
    12 Amarok
  10. #540
    Aug 2006
    Melbourne VIC
    U2ltr SS here you come Pete!
