Page 49 of 94 FirstFirst ... 39474849505159 ... LastLast
Results 481 to 490 of 937
Thread: Another Wreck, another Race Car.....
  1. #481
    Oakleigh VIC
    Project's slowed a little whilst I accumulate funds for engine components.
    Meanwhile I'm trying to knock off all the chores, the little stuff that takes more time than it should.
    I lobbed the 16v and a spare box in the bay so I could figure out some stuff.
    I decided against the recommended routing of the CAE shifter cables as I've read the less bends the better.
    As this isn't a street driven car I can lose the slack in the cabin.
    I also did some welding on the exhaust manifold to include the o2 sensor bung. I needed to have it in the car to see where it would fit.
    Now the manifold is sorted I can send it out for ceramic coating.
    I'll need to fab a heat shield for that steering boot.
    Haven't bothered doing much adjustment to the shifter. This was just to locate the firewall holes.
    There's a bit of slack in the shifter cables, I think I'll hold them down to the floor with some sort of clamp.
    Installed the remote for the kill switch. I had to make a spanner to do the effing nut up under there.
    Cable enters the cabin via a grommet directly below the handle.
    Haven't figured out a final position for the main kill switch yet.
    I'm not planning on using a dizzy so here's the beginnings of a blank off plate.
    I made it in 2 pieces because that's the scraps I had lying about.
    Not going to buy a billet for a little thing like that.
    Geoff Hale donated some stub axle spacers to the cause.
    "Some assembly required."
    I managed to find an original Rallye Racing decal online from Germany.
    Top decal is the original below it is a reproduction I made from it in vinyl.
    Now that I've done the artwork I'm going to scale a pair of the to fit the headlights nicely.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #482
    Jun 2007
    Eastern Suburbs Melbourne
    Great work Pete!
    i like volkswagens
  3. #483
    Dec 2008
    sydney
    Love the shifter and pedal set up, looks so cool.
    Awsome work.
    MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
    MK6 GTI: MY13, DSG , very stock
    Ducati 749
  4. #484
    this is coming along very nicely!!!
  5. #485
    Oakleigh VIC
    Made some parts.
    I needed some clamps to hold stuff to the rollcage so I made some from some 16mm aluminum plate.
    Here's some pictures in no particular order.
    Local wildlife helping out again.
    Bit of cleaning up to do at this stage, you'll see what they're for in a post or two.
    7? MK1 Caddy
    12 Amarok
  6. #486
    Oakleigh VIC
    Got around to finishing off attaching the throttle throttle cables to the pedal box.
    This is a delicate little job, that bit is only 3mm diameter.
    Put a flat on the pedal shaft for the grub screw to lock onto.
    This is the part that attaches the cable to the pedal. I really hate unreliable throttle linkages, this is probably over engineered.
    Cables coming into the engine bay.
    And the pedal box back in the footwell.
    7? MK1 Caddy
    12 Amarok
  7. #487
    Jun 2006
    Orange NSW
    Good stuff, mate. Looking very nice.
    I see you bought some machines, Pete. Nice work. Had the mill long?
  8. #488
    Oakleigh VIC
    Another quick job, I mounted up the rear view mirror.
    This came with rollbar mounting clamps but I couldn't use them as there's not enough room between the bar and the windscreen frame to use them.
    So rather than use the included clamps I made up a couple of new ones that bolt into a couple of nutserts I put into the bodywork.
    Here's the bracket I knocked up from some 5mm aluminium angle.
    Brackets installed.
    Super wide angle 17" mirror from Joes Racing.
    The view is crazy wide you can see out of the doors!
    7? MK1 Caddy
    12 Amarok
  9. #489
    Oakleigh VIC
    Not long, trying to remember all the stuff I forgot in TAFE 20 years ago.
    7? MK1 Caddy
    12 Amarok
  10. #490
    Jun 2006
    Orange NSW
    Nice. Mill is next on my list, mate. I know the feeling- Hard enough remembering the stuff you did 2 weeks ago! haha.
