Project's slowed a little whilst I accumulate funds for engine components.
Meanwhile I'm trying to knock off all the chores, the little stuff that takes more time than it should.
I lobbed the 16v and a spare box in the bay so I could figure out some stuff.
I decided against the recommended routing of the CAE shifter cables as I've read the less bends the better.
As this isn't a street driven car I can lose the slack in the cabin.
I also did some welding on the exhaust manifold to include the o2 sensor bung. I needed to have it in the car to see where it would fit.
Now the manifold is sorted I can send it out for ceramic coating.
I'll need to fab a heat shield for that steering boot.
http://www.vwwatercooled.com.au/foru...P1350822-1.jpg
Haven't bothered doing much adjustment to the shifter. This was just to locate the firewall holes.
http://www.vwwatercooled.com.au/foru...P1350823-1.jpg
http://www.vwwatercooled.com.au/foru...P1350824-1.jpg
http://www.vwwatercooled.com.au/foru...P1350825-1.jpg
http://www.vwwatercooled.com.au/foru...P1350826-1.jpg
There's a bit of slack in the shifter cables, I think I'll hold them down to the floor with some sort of clamp.
http://www.vwwatercooled.com.au/foru...P1350831-1.jpg
Installed the remote for the kill switch. I had to make a spanner to do the effing nut up under there.
Cable enters the cabin via a grommet directly below the handle.
Haven't figured out a final position for the main kill switch yet.
http://www.vwwatercooled.com.au/foru...P1350832-1.jpg
I'm not planning on using a dizzy so here's the beginnings of a blank off plate.
I made it in 2 pieces because that's the scraps I had lying about.
Not going to buy a billet for a little thing like that.
http://www.vwwatercooled.com.au/foru...P1350834-1.jpg
Geoff Hale donated some stub axle spacers to the cause.
"Some assembly required."
http://www.vwwatercooled.com.au/foru...P1350836-1.jpg
I managed to find an original Rallye Racing decal online from Germany.
Top decal is the original below it is a reproduction I made from it in vinyl.
Now that I've done the artwork I'm going to scale a pair of the to fit the headlights nicely.
http://www.vwwatercooled.com.au/foru...P1350837-1.jpg
