Originally Posted by
gldgti
is it normal/good/advisable/advantageous to run without the brake backing plates? (not a loaded question - just wondering. I always thought that the backing plate is probably designed (atleast in VW's case) to be useful to some degree with cooling or at least keeping heat away from the brake hose)
I had my rear backing plates removed by my (race) mechanic after he found that I'd cracked one of the rear pads.
Resident grumpy old fart
