Page 43 of 94 FirstFirst ... 3341424344455393 ... LastLast
Results 421 to 430 of 937
Thread: Another Wreck, another Race Car.....
  1. #421
    Jun 2007
    Eastern Suburbs Melbourne
    so exciting!
    i like volkswagens
  2. #422
    Dec 2008
    Bentleigh, Melbourne
    this car is looking too good for racing!! i love your attention to detail on everything.
    again, cant wait to see this tearing it up!!
  3. #423
    Boronia VIC
    Spent most of yesterday running around trying to find fasteners and brake fittings.
    Stripped down 3 separate steering columns to find good bearings which I cleaned up and re greased.
    I sandblasted the rack and column before painting them black.
    The column got a couple of extra braces welded to it as stock ones tend to fail.
    The steering shaft boot is original from the car, oddly the best one second hand I've ever come across.
    Sorted out the lines to the reservoirs. Probably overkill. I'll make a stay to make sure the clutch line doesn't get near the column or perhaps a right angle elbow.
    I cut the steering lock off the column. Some racing classes demand that the steering lock is removed.
    For the moment the column is in the stock location, once the seat is in I might lower it a few inches
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  4. #424
    Jan 2012
    UK South Wales Europe
    Great updates as usual.
    Peter with the steering column brackets people tend to also run a brace across from one side to the other to remove a bit more flex and increase the life of the brackets.
    http://img.photobucket.com/albums/v9.../DCP_6188s.jpg
  5. #425
    Boronia VIC
    Quote Originally Posted by fthaimike View Post
    Peter with the steering column brackets people tend to also run a brace across from one side to the other to remove a bit more flew and increase the life of the brackets.
    Yeah, I think there's more mods to come on that column, I doubt it's in the right place yet. Needed to get it in situ to sort out placement of bits and pieces.
    I think it'll be out again before I'm finished.
    7? MK1 Caddy
    12 Amarok
  6. #426
    Jan 2012
    Ah i mean the brackets in the engine bay sorry, pic attached to my last post as example.
  7. #427
    Boronia VIC
    I was wondering if that's what you meant.
    The early cars like mine don't really suffer from that problem as the rack bolts up solid at both ends. The supporting brackets are different and I've seam welded them in any case.
    7? MK1 Caddy
    12 Amarok
  8. #428
    Jan 2012
    Yes i thought they looked a bit different, only the very early ones were solid
  9. #429
    Dec 2008
    was great to see the car today peter, really looks great!!!
    again, thanks for the parts
  10. #430
    Boronia VIC
    Got a tank in over the weekend, it's a diesel one I've cleaned up.
    Need to source a suitable roll over valve for the breather.
    Suitable fuel hose for the tank to filler connection is 38mm if anyone needs to know. I got this piece from Purple Pig. (Yes that's a real business! Purple Pig - Industrial hoses, fittings and rubber products.)
    7? MK1 Caddy
    12 Amarok
